Question about Kodak EasyShare M1033 Digital Camera
? necessary to format a new SDHC 8 gb card before using ?
I have just purchased a new Kodak Digital camera - model M1033. Do I need to format a SDHC 8g card before using? I see no reference in the on-line manual. Sure wish that this camera had a detailed manual in the box when purchased. I do not appreciate time it takes to go on-line to learn about this camera.
I own another Kodak Digital camera - model DX7630 and all cards always had to be formatted in the camera in order to use.
Please advise. Thanks, Priscilla
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Yes. Cards should always be formatted in the camera before use and every time after you finish downloading the pictures.
Posted on Nov 26, 2010
My SD card will not format
Get an SD card. Your 8GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work with your camera. You need to use an SD card, 2GB and smaller.
Jul 19, 2012 | Kodak EasyShare CX7530 Digital Camera
I just purchased a SanDisk 8 GB SDHC card for my Kodak EasyShareC743. When I inserted it, it said it needed to be formatted, I hit continue, then is said it would delete anything on the card, I hit...
The C743 works with MMC and SD cards, not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to go with cards 2GB and smaller.
Jul 07, 2011 | Kodak EasyShare C743 Digital Camera
Can i change my memory card from 2GB to 4GB or 8GB
Yes, the Kodak Easyshare M1033 has a SD/SDHC compatible expansion slot so you can purchase and insert memory cards up to 32GB. You can purchase them almost anywhere like Best Buy, Target, etc.
Mar 31, 2011 | Kodak EasyShare M1033 Digital Camera
Purchased new memory card. camera screen said to format card, camera will not format card please isnsert another. new card is kodak 8gb sdhc. it works in a different kodak camera
The DX6490 works with MMC and SD cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. Some Kodak cameras can use SDHC cards, but the DX6490 is not one of them. You need to go with SD cards, 2GB and smaller.
Feb 19, 2011 | Kodak EasyShare DX6490 Digital Camera
I purchased a 4 GB SDHC card for my kodak easy share dx6440. The camera keeps rejecting it because 'it is not formatted'. I formated it and it still does not read it. is the DX6440 limited to SD 2GB? ...
The DX6440 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You are limited to SD cards 2GB and smaller.
Nov 09, 2010 | Kodak EasyShare DX6440 Digital Camera
The camera says I need to format my memory card and when I do so the screen reads Filesys errore00100, how can I fix this?
The card may be incompatible.
Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 07, 2010 | Kodak EasyShare C310 Digital Camera
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting" continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
150 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
