Transmission fill how much oil and weight
I need to fill transmission and I need to find out how many Oz of oil is required for this model and also the weight of this oil or if can I use regular gear oil for cars, any advise.
Thanks
  • 55 Answers
As in any gearbox the weight of the oil is reasonably important as this regulates spin of rotary parts, keeps thing at certain temperatures and obviously reduces wear and tear... However washing machines spin at fairly low R'sPM so the viscosity(or weight) doesn't really matter. To fill simply pour enough oil so that you can just see the suface of the oil in the hole, possibly using a flashlight or, feeling with a finger or bent wire.
Posted on Mar 09, 2009
2001 FXSTS Fliud Capacity
Hi Tom, the following is fluid requirements for 2001 FXSTS:
Engine oil-3.5 qts. with filter.
Primary oil-26 oz.
Transmission oil-20-24 oz.
Have nice day.
Apr 16, 2013 | 2001 Harley Davidson FXST Softail Standard
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
How many quarts of oil is require on a 2003 electra glide for a oil change
Hi Anonymous, oil capacities on touring models:
1. Engine oil 4 qts. with filter Hd Multi Grade 20w50.
2. Transmission oil 20-24 oz HD Transmission Lubricant.
3. Primary oil 32 oz. HD Primary Chaincase Lubricant.
Good luck and have nice day.
Jun 23, 2012 | 2001 Harley Davidson FLHT Electra Glide...
How many quarts of oil does a 2001 harley electra glide standard require for an oil and filter change?
Jan 25, 2012 | 2001 Harley Davidson FLHT Electra Glide...
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
Where is the location on a 1994 honda civic ex that i would fill the manual transmission with gear oil?
Manual transmissions have a fill plug and a drain plug on the side of the transmission. The fill plug is a little above the drain plug. Pull the fill plug and fill the transmission until the transmission fluid just barely seeps out and re-plug the transmission. That is the proper way to fill it. You will need a long stem funnel to give you the room you need to fill it. Your transmission requires a 10W30 weight motor oil, just like your engine. If you have a little time and 3 or 4 quarts of oil laying around you can pull the fill plug first and THEN the drain plug and let all the oil drain out. Then plug the transmission and re-fill it with fresh oil and this is a transmission flush for your transmission. You just saved $70 shop charge doing this. I say pull the fill plug first and THEN the drain plug because the last thing you want to do is pull the drain plug first and then find out the fill plug has welded itself and won't come out and now you can't fill the transmission. Fill plug first always.
Regards, Tony
Apr 17, 2011 | 1994 Honda Civic
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
Oil type for troy bilt weeder 4 cycle model # TB575SS
Non detergent, straight 30 weight.
Sometimes can be found labeled as "Tractor Oil". Otherwise, any premium 10w-30 I find in my experience with these stout 4-cycles to be just fine!
If breaking in engine from new, out of the box? Change oil with 10 hours on the clock with engine is still warm. You only need 3.2 Oz. to fill the crankcase!
So pour slowly. It is full when the trimmer is placed on a level workbench surface with the trimmer head dangling off the end. There is going to be a slight forward tilt away from the oil fill plug. Fill only until it just literally comes to the bottom of the oil fill plug with the trimmer laying flat on your workbench.
*DO NOT FILL IT UP WHILE HOLDING IT VERTICALLY!*
(I warned you. ;D )
Also at this time, clean and re-oil air filter and check your manual - these trimmers after break in require a valve lash adjustment. .005" @ TDC if my memory is correct....The manual I *think* states anywhere from .003 ~ .007 to be within spec. After break in, only need to adjust valves seasonaly. Regular oil changes @ 20~25 hours of run-time keeps them happy.
May 08, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How mutch fork fluid does it require for the xt 600
hay matey, best to use mums or the mrses plastic gravey jug,or if u have your own 4 measuring .. , in each fork leg u need 18.9 imp oz,,or 18.1 us oz of 10w fork oil or equivalent, after filling ,slowly pump fork up and down to distribute oil,, ,ok m8,, i had one of these babys,,so u no if its filled correctly, from the top of the inner fork tube, fully comprest with out the spring inserted,,, the gap from top of tube to the top of oil level , should measure 155mm,, hope that helps yuh
Jan 10, 2009 | 2000 Yamaha XT 600 E
Transmission Grease for A120 and D300
Thanks,, great info..
I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
Thanks again,, jaybeesee
Daniel from Penokee
Jun 13, 2008 | Hobart D300 Stand Mixer
Washing Machines Logo
254 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
