Question about Body Solid Best Fitness BFMG20 Sportsman Gym
BFMG20 Sportsman's Gym: Does this item come with the weights?
Does this gym set come with the weights. All pictures show weights but it does not specifically say.
  • conkie1996 Mar 09, 2009
    Thanks for any thoughts about responding to this. I was able to find my answer after further searching.
Included with the BFMG20 is 150lbs stackable weight plates.
Posted on Sep 13, 2009
I need a manuel to best fitness BFMG20 sportsman gym
please go to www.fitness.manualsonline.com or www.iconservice.com and download for free.
God bless you
Jul 13, 2012 | Body Solid Best Fitness BFMG20 Sportsman...
I have purchased a second hand orion delta home gym, without the instuctions. I have put together with the exception of the cables, and i can't workout the pulley cable system. Wwhere can i get an...
hi there i have a instuctions book for a delta orion multigym with a pic of pully and cables if you still looking drop me a line at theheatman@btinternet.com and i'll email you a copy of the layout
matt
Jun 13, 2010 | Powerline P2X Home Gym
Got cables connected on gym but number one weight is still not sitting of top of the oher weights it up a lil bit on body solid home gym 1500s
If the top plate is just hovering and you cannot adjust it out. For a while you may have to push the top plate down and engage the selector pin and with use the cable will stretch on its own with usage. Since these are a series of cables it would be difficult to pinpoint which cable is causing this problem. If you want to remedy this call Body Solid and have them send you a new set of cables.
Jun 09, 2010 | Body Solid Bodysolid Exm1500s Home Gym - ...
How do i set up York 1001 multi gym with no instruction manual
Go to www.yorkfitness.com click on the weight icon then the upper right hand side you will see customer support, then go to instruction download and then mutli gym and your unit pdf is their
May 09, 2010 | Exercise & Fitness
Weider 3650 home gym. Delay on the weights dropping back down.
With weider pulleys you will find that either the little retainer L shaped piece has moved on one or more of the pulleys or the pulleys are scraping against each other.<br />The plastic coating on the cables will start to show wear or you will be able to feel it in a while.<br />Also check to make sure the cables are around all the pulleys, and have not shifted to the shafts.<br />
Apr 17, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
I need a excercise chart for an old style weider home gym. It is one with 2 sides to it, one for sitting doing bench press, and pulldowns and ups. The other side for doing butterfly i think its called etc....
No you do not the is a book called the home gym hand book and it will give you all the information on how to use your gym. They also have home gym posters
Oct 05, 2009 | Exercise & Fitness
How do I create a home gym?
Figure Out Where the Home Gym Will Go The first step to creating a home gym is to figure out where it will be placed within the home. If you have a separate room which you can set aside as your workout location, this is ideal. However, for those who have limited space within the home, it is completely possible to create a home gym in a room which is used for other purposes as well. Take a good look around the home and determine which area would be most suitable for your home gym location. Determine How Much Space Is Available When creating a home gym you also want to determine how much space you will have available. Doing so in the beginning will help you to decide what type of workout equipment you want to buy for your home gym. Before making any equipment purchases, take down some measurements of the available space as this will prove helpful when shopping for workout products. Peruse Different Types of Gym Equipment Some individuals will know exactly what types of gym equipment they want to buy for their home gym whereas others may need to peruse the options before deciding on particular types thereof. Try searching various equipment options online and in fitness magazines to see which ones peak your interest. Also, if you are interested in working out specific portions of the body try searching for equipment which will work out those areas in particular. Shop for the Home Gym Equipment and Furnishings Once you have a good idea as to what type of home gym equipment and furnishings you wish to buy, the next step is to make the desired purchases. Buying items at sporting good stores and fitness retailers will often provide one with the most options. Try visiting your local sporting good stores so that you can view the equipment in person and even try it out. Later, if you figure out what brand equipment you want and have tested it out in the stores, look online for the items as these may yield the best prices. However, just be sure that the online retailers ship for free as these products are often quite heavy which can make for extremely expensive shipping costs. In addition to the fitness equipment, you may also want certain furnishings in your home gym. Items such as a chair, towel rack and even a television for viewing while working out may be good purchases. Consider what extra niceties might fit perfectly within your new home gym and check out options with regard to those as well. Time to Set up the Home Gym Once everything has been decided upon, purchased and received, the final step is to set up your new home gym. Prior to setting the equipment up you should already know where everything is going to go as it will be difficult to move things around too often due to the weight of a lot of exercise equipment pieces. Since most equipment will need to be assembled, try to do so in the home gym room as this will make for an easier time getting everything set up and ready to go. Once you have it all set up, you are ready to get started working out in the convenience of your own home. Need help paying for your home gym? Check out www.MyDreamHomeRegistry.com and make your dream a reality.
Dec 01, 2008 | Body Solid G4I Iso-Flex Home Gym
Body Solid Best Fitness BFMG20 Sportsman Gym Logo
303 people viewed this question
Top Body Solid Exercise & Fitness Experts
Howard
Howard
John
Tom Chichester
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
