Question about JBL PSW-D110 Speaker
How do you disassembly the JBL PSW_D110?
What is the disassembly process to gain access to the inside of the JBL PSW-D110 speaker unit?
What i did was i stuck my hand in the port, screw driver in hand, used the blunt end of the screwdriver put it in the indent on the magnet on the back of the sub, positioned it so that the end of the screw driver was stickin out and smacked it with a hammer and it popped out, make sure u take the screws out of the front of the sub, and then take the insulation out of the box and do the same thing to th eboard just do it on theblack part of the amp not on the board
Posted on Mar 29, 2009
What is the size of the JBL PSW-D110 fuse?
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
Jun 24, 2011 | JBL PSW-D110 Speaker
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
Need power transformer or replacement circuit board for psw d110
just get one from a old computer speaker system there the cheapest
Oct 16, 2009 | JBL PSW-D110 Speaker
JBL PSW D100 blown fuse
Not likely. There are no fuses according to the instructions I found for the D-110. I assume they're about the same.
Try it with nothing attached anywhere except the power cord. No light immediately = dead.
Nov 10, 2008 | JBL PSW-D110 Speaker
My JBL PSW-D110 started humming loud... The fuse is fine and the power LED displays is illuminated in green. However the sound is unbearable... It would like to replace the entire IC panel if its most cost...
Hi calsunbelt
there are some caps that fail in the power supply. If you are up to doing some electronic repairs, I could talk you through it and tell you what parts to check.
regards
robotek
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
JBL PSW-D110 Speaker Logo
340 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
