Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Pressure washer won't run. It starts and runs for a second then stops. I've tried and tried, several days. Methinks it's the carburetor gummed up since I left it outside all winter, sheltered, and didn't empty the gas. Can I fix this myself?Briggs and Stratton Sprint 3.75
  • jbjb Mar 12, 2009
    Well, shoot, I just took it in for a tuneup and possible a carb cleaning. Should get it back in two weeks (poss. costing $60). Thanks for your advice. I would like to have been able to fix it myself, but sometimes you just got to give up!
  • D Thing May 16, 2009
    Sears pressure washer starts fine but stops almost immediately because it appears to be under pressure. If you remove the siphon fitting and let it leak the engine runs fine. I think it is a problem in the high pressure pump not relieving itself or leaking of to the vane in the pump stalling it
  • 3 Answers
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing... ">
Posted on Aug 17, 2011
  • 42 Answers
I am guessing that you have a hole or crack in one of your fuel lines. check them first, if they are all good, you are probably right, it needs a good carb cleaning. If you get me the model and type numbers off of your engine, I can get you a parts breakdown for that also, if that would help at all. Let me know. Thanks.
Posted on Mar 12, 2009
  • John McKinney Mar 12, 2009
    If you would, ask him what was wrong and let me know. I am always trying to sharpen my skills for you guys. Thanks.
  • phillipha189 Apr 23, 2011
    i cleaned the carb and checked my jets 1 seemed to be stopped up to a small piece of wire and it was solid did not clear it was almost as if someone plugged it im not real sure need help dont know a hole lot about carbs.
Starts and runs. Shut off. Won't restart for one hour. What's wrong?
Gas pumped today contains as much as 10 percent domestically produced ethanol. Gummed-up fuel systems
90 % chances the carburetor needs cleaning.
take the bow of the carburetor ..may see some brown stuff,,
Oct 02, 2015 | Garden
Troy-bilt pressure washer 3000 max psi 2.7 gpm not getting gas
The carburetor ports and jets are likely clogged with gum from fuel that contains Ethanol. Avoid using any gasoline that contains Ethanol in small engines. Use only 100% gasoline. You can try the simple method first by adding some Lucas to the gasoline and a tad bit directly into the carburetor. Also, remove the bowl under the carburetor to see if it's gummed up and stopping the float from setting and rising. Simply clean the gum off with carburetor cleaner and replace the bowl. If this doesn't work then you'll likely need to remove the carburetor and do a thorough cleaning on it. Be sure to replace with new gaskets.
May 19, 2012 | Briggs & Stratton Garden
I have DeWalt3750 psi pressure washer, its been long time since I used it, now that I wanted to use it, I can not start it. I already changed the oil and filled it up with new oil but still can not start,...
Here is the long answer with everything we learned while using a power washer twice a day for years::
This assumes you did not turn power washer over or on its side to drain oil, or dirty oil will flow into carburetor requiring complete carburetor cleaning.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
Nov 28, 2010 | Dewalt 3800 PSI Pressure Washer
I have a pressure washer at work that has good spark and starts when I put gas in the carburetor.But it wont stay running. I have the gas turned on but it doesn't seem to be getting to the carb. It's...
Here is the long answer with everything we learned while using a power washer twice a day for years:: It covers the things you already tested, but doesn't hurt to repeat. Your problem is actually #8 on list below.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or machine would die. We still use machine at 2/3 throttle, and then start each time using WD-40 as described below.
If engine will not fire on WD-40, then your spark is suspect.
Nov 22, 2010 | Honda Pressure Washer PSI 3000
Can not start the engine
Nov 01, 2010 | Karcher G3025OH Pressure Washer
My pressure washer is 3 years old, never had a problem with it until now. It runs for 2 seconds only on choke. It will not start or turnover at all with out the choke on. Please help, I miss my...
Now the nitty gritty of starting that bad boy and making you happy again!!!!
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week. Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal. If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Let us know how it comes out!!
Oct 15, 2010 | Honda Black Max 2600 PSI Pressure Washer
What would cause a pressure washer to cut off after you pull the handle to get the water started
We used power washers for years
When you pull the trigger, the engine is supposed to accelerate because the back-pressure on the pump is released.
The back-pressure is why you're supposed to keep the gun trigger open when starting the engine. It sounds like you're starting the engine with no water passing through the gun.
Inspect the exhaust port >> if exhaust is clogged with carbon or dirt, then the engine will not run at high speed.
The problem may also be cause by a rusted choke lever. If you notice when a small engine accelerates, the choke lever moves up as the carburetor demands more gas.
Start the engine with water passing through the gun >>> move the choke lever a little bit at a time and see what happens. Keep water going out of the gun. When the surfaces are cool, spray WD-40 on the lever and see if you can free it up. WD-40 is extremely flammable.
If your engine will not fire at all by starting with water passing through the gun, then your gas supply might be limited or your carburetor gummed up. Pull off the rubber gas line that connects to the carburetor and see if gas flows.
Next, pull off the air filter and see if the machine runs good without air filter. You may have clogged air filter.
While the carburetor is exposed, spray WD-40 into carburetor. See if you can get engine up to full throttle while spraying WD-40 into carburetor. Keep spraying the WD-40. Keep the water flowing out of the gun.
If the engine throttles up all the way on WD-40 but won't run without it, then your carburetor is probably gummed up.
Our old power washer won't run with the choke set at full throttle. We just got into the habit of leaving the choke alone. We'd pull off the air filter and spray WD-40 into the carburetor so the engine would spark healthy without messing with the choke at all. And we kept the choke about 2/3 open all the time.
Oct 15, 2010 | Garden
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
I have a problem with my karcher 2500 pressure washer with honda engine it will not start or stay running. I have used starting fluid to start it it starts but won't stay running.
Carb is mostly likely gummed up and should be cleaned. Best option is to dismantle the carb and soak in solvent or equivelant for a couple hours and replace it. Our use Gum Out. Do make sure you have a good spark plug and a strong spark. If you have a fuel filter, then replace it. Check intake filter as well
Aug 05, 2009 | Karcher 2500 PSI Pressure Washer
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
1,236 people viewed this question
Top Psi Garden Experts
John Trevino
Ron Lankford
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
