Question about Intel D915GEV Motherboard
Hi, pc doesn't load bios
Hi
I cleaned the motherboard, with no solvents/liquids, reseated the RAM (4x ram cards) and applied new thermal paste.
Now, after re-assembling the PC it doesn't boot past the inital motherboard logo screen, and if I press delete it indicates Loading Setup... but doesnt.
The motherboard is D915GEV, and there are no beeps from the boot sequence. It doesn't get to the Setup BIOS screen. HELP!
Thanks
Victor
I have remove the hard disk and and removable drive cable and then try but result is same.
Posted on Aug 29, 2009
  • 158 Answers
Hey just remove the hard disk and and removable drive and then try.
And check that your hard disk data cable and cd/dvd driver data cable is in good position or not. Many times the problem is happens because of cable. So you just try a new cable.
Posted on Mar 09, 2009
Ram not reconized by motherboard
Before you pronounce it dead, try removing the ram chip(s), wipe the contacts clean with a pencil eraser and reseat them onto the motherboard 2-3 times.Still doesn't work, try new ones. Still doesn't work. Bad motherboard.
Apr 16, 2014 | Dell Dimension E520 PC Desktop
Tip
No Display In Motherboard
Hi,Thanks for using fixya,
Switch off the computer and open the pc cover.
First check the ram,and clean by eraser or with solvent and install again.If the problem is same, install the ram to another computer to ensure either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold" on off "switch for 40 seconds. Install battery again and start pc.
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.clip_image003.jpgclip_image004.jpgclip_image005.gif
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmclip_image007.jpghttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image009.jpghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blink with a long times or not.
If the floppy drives led light on, download updated bios your Intel mother board,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmos jumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNow switch on motherboard, hope, through these processes,should recover the mother board.
If the problem is same, try to install a graphics card. For same problem I will recommend you for new motherboard.
Hope this helps,.
Thanks for using fixya.
on Jan 24, 2011 | Computers & Internet
Twice beep sound is coming. Booting is not happening for my p4p800 mx/s board
Hello !
If you check out ASUS support, you will find this troubleshooter for the motherboard not booting :
1. Please clear CMOS.
2. Please take out your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Please take the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Please keep the necessary components(CPU, one memory) onboard for a test.
Finally, we would recommend you to replace a BIOS battery to have a test.
Also, by looking over beep codes I have found for AMI BIOS these problems for the 2 short beeps :
1. Memory parity error (Description : A memory parity error has occured in the first 64 KB of RAM. The RAM IC is probably bad).
2. POST fail (Description : One of the hardware tests have failed).
If you have done those and it still doesn't boot, let me know I'll try to find other solutions.
All the best !
Aug 03, 2011 | ASUS P4P800-MX Motherboard
I AM NOT GETTING ANY DISPLAY ON THE MONITOR. I HAVE CHECKED MY RAM AND PROCESSOR BOTH ARE WORKING AND SERVICABLE.
Hi, Switch off thecomputer and open pc cover.
First check the ram, clean by eraser or with solvent and install again, if theproblem is same install the ram to another computer either it damage or not .Ifthe problem is same change ram.
If same as before, remove the cmos battery or clear the cmos jumper andhold" on off "switch for 40 seconds. Install battery again and startpc.
Now please check the "smps" by another new or by your"smps"to another pc to confirm either it damage or not.clip_image001.gifclip_image001.gifclip_image001.gif
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
1.Change all the bad capacitors, beside the processor, with the help by nearesttechnician. http://cquirke.mvps.org/badcaps.htmclip_image001.gifhttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image001.gifhttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent markerbecause you need to remove and install it. It could not be possible for allmother board.clip_image001.gifclip_image001.gifclip_image001.gifclip_image001.gif
3. Remove bios chip from base, clean with solvent and install it properagain.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and,watch the "led light",( floppy drives )either Blink with a long timesor not.
If the floppy drives led light on, download updated bios your Intel motherboard,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, soplease use ups and insert the floppy, along with bios file. Set the cmosjumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNowswitch on motherboard, hope, through these processes, should recover the motherboard.
If the problem is same, try to install a graphics card. For same problem I willrecommend you for new motherboard.
Hope this helps,.
Feb 27, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Display problem . i change ram & smps&i install extrenal vga card but no dispaly
Hi, Thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again, if theproblem same install the ram to another computer either it damage or not .Ifthe problem is same change ram.
1.Change all the bad capacitors, besidethe processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htm clip_image007.jpg http://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svg clip_image009.jpg http://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent markerbecause you need to remove and install it. It could not be possible for allmother board. clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again. It could not be apply for all mother board. ONLY FOR INTELPLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blinkfrequently in a long times or not.
If the floppy drives led light on, download updated bios your Intel motherboard, and use a floppy disk for restorethe bios , Download link. http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22 .
5. Don't switch off your motherboard atthe time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmosjumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm http://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htm Now switch on motherboard, hope, through these processes,should recover the mother board.
Hope this helps, .Reply me for another instruction. Thanks.
Feb 25, 2011 | Intel D945GCL Motherboard
Not display image
Hope this helps,.
Feb 22, 2011 | Computers & Internet
Mother can not boot up. bios is damage
Hope this helps,.
Feb 18, 2011 | Gigabyte GA-K8NE (04719331711023)...
Video problem
Hope this helps,.
Feb 18, 2011 | MSI K8MM-V Motherboard
My motherboard gives 8 beeps and shows no video, I tested with several video cards and gives the same result. when the computer beeps (normal as it recognizes that although the bios), then emits...
Continious beep codes are caused by the memory (RAM). Try reseating your RAM just plug it out clean it then put it back in. Or try the other memory slots. Just transfer your memory to the other slot if you have an available slot on your motherboard. Or simply buy a new memory (RAM). Just make sure it is compatible to your motherboard. Beep codes means the computer is not reading the memory (RAM) properly. There is no post and no video in your computer because the RAM is not working properly.
Dec 19, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
My EVGA 780i will not post after installing a new heat sink. No post codes, no beeps. I have three LED lights on the mobo that are lit. Green, yellow, and blue. I have tried reseating ram, trying 1...
hi mate, here is a few things to try btw i hope you used thermal paste when you replaced the GPU heatsink as if you boot with out the thermal paste there always a chance if you didnt that the gpu got hot fried in a few seconds ( i have seen it happen)
1) remove the graphics card and clean the motherboard socket it plugs into with a paint brush i noticed you did try a alternate slot but there still could be debris in the primary graphics slot causing a problem ( alot of the time dust from the cpu fan builds up on the graphics card slot and when you remove the card and put it back in the dust or debris gets pushed into the graphics socket on the motherboard )
2) while the graphics card is removed use a cotton tip dipped in isopropyl alcohol or metholated spirits if you cannot get isopropyl alcohol and clean the gold connectors on the graphics card where the card plugs into the motherboard
3) perform the same above 2 steps on the ram dimms and the ram slots incase there is debris or dust there
4) see if your pc has a onboard graphics port and try removing the graphics card and running the pc off the onboard graphics only if it works from the onboard graphics then you at least know its the graphics card and not the ram or board, if the onboard display doesn't work when the graphics card is removed then the problem is likely in the motherboard
5) test you motherboard encase its broken - remove you graphics card and the ram sticks and turn your pc on, it should beep loudly at you-
- if it beeps the board is generally fine
- if it doesnt beep when the ram and other cards are removed then it could be the motherboard
other then that your limited as to being able to test further unless have a second pc to test the card in or a second card to test in your main pc,
Apr 19, 2017 | Evga nForce 780i SLI 3xPCI-E x16 PCI-E 2.0...
Intel D915GEV Motherboard Logo
146 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
