Question about Lionel 52025 Madison Hardware Tractor & Trailor
Power in bed room went out change breakers and still has no power.Trace wire from electric box under home but can not trace any futher because it goes up into the floor and that one wire has no power to it at all.Where could i find a schematic for my 1993 topgun Imperial mobile home. Thanks, In the DARK.
  • 32 Answers
Check with a volt meter see if there power at the switch. Also did you check the bulbs?
Posted on Mar 09, 2009
Intermittent Intermatic Pool Timer T40003RT3 The pool timer is 220v but only one 110v 20amp breaker in the breaker box to the pool equipment and when it is off the pump will not run in manual mode.
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#RT3
RT3 series has T104 240 volt timer -or- T103 120 volt timer, -plus- low voltage transformer for pool light.
The circuit breaker can be used for transformer, or another outlet or nearby light etc, or it can be used for a T103 120 volt timer.
To trace the wire back to breaker box.... open you main panel and start turning off breakers one at a time and label the panel.
See if you have single breaker or double breaker supplying power to pool equipment.
Gene
Water Heater Timers Save Money
Jun 10, 2015 | Intermatic Timer T40004RT3 300 Watt Pool...
Wiring schematic
There should be a junction box located outside under the floor and will have a "pigtail" wire going from it to inside the frame of the coach. Beyond that you have to trace the wiring as there aren't any published wiring diagrams.
Mar 14, 2014 | Dutchmen 2012 Denali 289RK
General electric 200 amp breaker box. Power went out to all but 1 room.
I am no electrician, but it sounds like your box is too small for your house. Just saying. I would get an electrician to check the size or call somewhere like Lowe's or Home Depot and ask someone in the electrical dept.
Feb 15, 2013 | General Electric Electrical Supplies
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
All circuit breakers good in box. have no power to 3 rooms on outlets or lights . problem started when using a hair dryer hooked too a drop cord in a outlet
the first thing that I would check is to see if there is a GFI outlet inline with the other outlets that are not working,, if there is one then check to see if you can reset it using the little reset button -- if by using the reset button does not fix this problem then there is the chance that the GFI outlet is bad and needs to be replaced. the next thing that comes to mind is that you said the breakers in the box are good, but I have seen sometimes where you need to flip the breaker totally off and then back on and this could reset the breaker. if you are still having troubles then the problem could be that one of the outlets in line has gone bad and needs to be replaced or the breaker in the box could also be bad ( use a meter to check that you have power on the output side of the breaker and trace from there from outlet to outlet until you find the bad one ) ---- could also be just a bad wire and while testing with your meter you should find it as you test the wires to the outlets.
c...
Jan 23, 2011 | Electric Drill Scaler
My ge smart digital timer has been installed for over a year now and it just stopped working. the screen is blank. any ideas about what is going on with it
The GE digital timers are powered by the electric circuit.
A wire could have come loose inside the box.
The circuit breaker tripped.
A loose wire in the box proceeding the switch box (each box is linked to the next box as the wires trace back to the circuit breaker)
Try replacing timer with ordinary switch or test for power inside timer box.
These timers come with 1 year limited warranty.
If your load (lights fan motor) is close to wattage capacity of timer, the timer gets warm and doesn't last as long.
Oct 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Suddenly the light and the fan quit . Is there a reset
the only "reset" is the circuit breaker.... if they both suddenly quit working, there is no power to the hood at all.... if the breaker/fuse at the box is good, then the hot wire has slipped out of the connection.... not an easy way to trace it. all you can do is work backwards, starting at the power box up inside the hood. if all those connections are tight (power supply to unit's wires) then it's in the wall, attic, or under the floor.... no fun.
Nov 26, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
My trace inverter SW2512 will only allow pass through power.
First problem is caused by the new generator producing too high a frequency... 65 Hertz is above the inverter limit. Adjust the governor down to 60 or 61 Hertz.
Breaker tripping may be due to excessive current draw from the Honda. Check the max AC input menu on the inverter. It might have been set lower to avoid overloading the original generator but if DC power was turned off at any time while you were changing generators, the inverter would have returned to it's default settings which may exceed the Honda's capacity.
Mar 29, 2009 | Xantrex Technology Trace Series Inverter /...
Modular Home Wiring Schematics
Won't be a wiring schematic for it. If it is a modular it will be wired same as a house. Unfortunaltly it will be wired by the lowest paid electrician you have ever seen. LOL. If the wires are hot, put a multimeter on them and have someone flip the breakers one by one to identify the wires and breakers. If they are not causing any problems then they are just spare connections. Don't know why they would even be there.
Dec 11, 2007 | Computers & Internet
Will start and run, but no heat.
These units have two circuit breakers...generally hooked up in tandem. It is always possible that the heater element is out. Sometimes they open a breaker when they fail. If you see a wiring diagram on the back of the unit and are handy with a multimeter...available at the hardware store...you can trace this out. Remember to turn off the power if you do.
Sep 16, 2007 | Roper RES7646KQ Electric Dryer
Lionel 52025 Madison Hardware Tractor & Trailor Logo
239 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
