How do I remove the sliding sunroof cover to repair the headliner?
SOURCE: Hearing wind and road noise from right front of car and sunroof.
check the seals the rubber around window has anyone put anything on top of your car open the sunroof check the inside as it closes / to move the sunroof up or down after resting there are bolts on ech side at front theat you can un bolt push up and tighten up/ thanks for using fix ya please rate my response thank you very much
SOURCE: 2005 Jaguar S-Type pairing
Here you go:
http://www.jaguar.co.uk/uk/en/owners/owner_information/bluetooth.htm
SOURCE: how to remove the front dorr panel on s type
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls and mirror. Then you can access the bolts securing mirror onto the door
SOURCE: How do you remove the headliner from the inside of
Unless you are wizard, taking it down is only about a quarter of the job. You will only be able to remove through the front windshield and recovering it, is not a job for amateurs. Wait until you need to replace the windshield, then the same shop should be able to replace or repair it for you.
To check the condition of your original sunroof guides:
- Gl*** in closed position.
- Locate & remove 3 torx bolts on each side of sunroof glass. Lift glass out of sunroof opening & set aside in a safe place.
- Locate "J" shaped cover plate at front of sunroof track assembly. Remove 2 torx bolts from each cover plate.
- Lift up bracket to remove.
- Inspect the plastic guides on each side. The sunroof cables attach to guides on front outer corner. Inspect this area closely for damage.
- Do not operate the sunroof with the J plates removed.
Troubleshooting:If the sunroof guides are not broken & the glass is a uniform height along the rear edge your problem may be a stripped gear inside the motor. The motor has a manual override:
- Get access to the motor by removing the map light/switch console or lowering the front of the headliner.
- Insert a large standard screwdriver into the nylon bushing at the center of the motor hub. Push up & turn the screwdriver to manually move the sunroof glass. If the unit will fully open & close manually, you most likely only need a replacement motor.
If your sunroof is stuck in the open position follow these steps to get it closed:
- Remove the glass.
- Try to close the unit without the glass. Many times one side will still be operational and close correctly.
- Try to slide the inoperable lift arm forward. If it moves, slide it forward until it stops.
- You now need to slide the original plastic guide forward to lower the arm to the closed position. Using a standard screwdriver, push it forward. The lift arm should begin to lower.
- If the lift arm will still not fully lower, remove the J plate as explained above, sometimes the sunroof cable will need to be lifted up to allow the guide to fully slide forward.
- Reinstall glass.
J 2772-C Headliner Installer
