Sewing Machines Logo
Posted on Apr 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i buy a thread tree for a brother lock929d
Mine has broken off so need to replace it
Debbi's Sewing Machine Repair
Level 3:
  • Brother Master 7,365 Answers
  • Posted on Apr 13, 2013
Brother Master
Level 3:
Answers
7365
Questions
Helped
1744166
Points
19451
1 Related Answer
Anonymous
  • 1788 Answers
  • Posted on Sep 12, 2010
SOURCE: i need to buy a
Go to sewingpartsonline.com or brother-usa.com
How do u thread a brother serger 834dp
Perhaps the following will help. Most machines within a brand will thread the same way:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiTrYHH79LUAhVE4mMKHYKUBFUQFggsMAE&url=https%3A%2F%2Fwww.brother-usa.com%2FModelDocuments%2FConsumer%2FUsers%2520Manual%2FUM_PL_2100_EN_238.PDF&usg=AFQjCNF99J5PVNoFcHjv5FJcR-6eyNqTNg&cad=rja
HINT: Be sure to ALWAYS RAISE the presser foot when threading. Give each thread an extra little tug when going from the thread tree to the tension disk. AND BE SURE TO THREAD EACH IN THE ORDER SPECIFIED! Threading out of order will almost certainly guarantee failure!
The telescopic stand with thread holder has broken - is it possible to order this part?
Yes, usually you can find replacement thread tree. Search the internet for the:
Make + Model + the word "parts" or "thread tree"
If not, you may be able to buy a generic brand and modify it to work.
Why does the upper looper thread keep busting?
Quite possibly the machine is not threaded correctly, the tension setting for that looper is too tight (could be the upper looper tension disk is stuck or dirty causing the thread to hang), or the thread is looped around something like the thread tree.
Replace the needles. Remove all the thread and re-thread from the beginning. Be sure to RAISE the presser foot before threading. Make sure to thread the threads in the correct order.
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
2answers
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
2helpful
3answers
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
4answers
Brother Serger 634d
where can i buy a new thread tree for my 1034d brother overlocker from betty c
4helpful
4answers
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
