Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Running Mac OS 10.5.6 on a MacBook Pro. Recently tried to make a short video using Quicktime Pro version 7.6.0 and the video window opened alright, but when I tried to start by clicking on the button, I got an instant message that the video didn't start. Repeated several times with same result. I did use the program a couple weeks ago and everything worked fine. I don't know what things to check and don't want to just reinstall without determining the problem. Any ideas? Bert
The application will not open in windows 10. Uninstalled it, removed folders& regkey entries.Installed clean version. Installation went fine. However the application it self will not open.
According to the software release notices, it wasn't until version 7.0d that they made it Windows 7 compatible. You aren't saying what OS you are migrating from, but it may be that you are running too old a version of the program. You could try one of two other options.
  1. Try running the program as an administrator. Right click on the program icon and select "run as administrator".
  2. Try running in compatibility mode for the OS you were using it with previously, right click on the program icon and select the "properties item". Then click on the compatibility tab and use the pulldown to select the OS to simulate the program for.
If they both fail to work, you may have to upgrade to a newer version. Many older applications stopped playing nice starting with Windows 8. Many of them actually worked if you loaded VISTA drivers and/or compatibility, but not all. Most Windows 7 and later software has no issues with Win10.
Oct 02, 2015 | Sony ACID Pro 7 for PC
Tip
How to Convert DVD to QuickTime
QuickTime is an extensible proprietary multimedia framework developed by Apple Inc., capable of handling various formats of digital video, picture, sound, panoramic images, and interactivity. It is available for Mac OS classic (System 7 onwards), Mac OS X and Microsoft Windows operating systems.<br /> QuickTime is integrated with Mac OS X, but it was once an optional component at install for earlier versions of Mac OS. QuickTime for Microsoft Windows is downloadable, either as a standalone installation or bundled with iTunes.<br /> QuickTime is available free of charge for both Mac OS X and Windows operating systems. Some other free player applications that rely on the QuickTime framework provide features not available in the basic QuickTime Player. For example:<br /> &bull; iTunes can export audio in WAV, AIFF, MP3, AAC, and Apple Lossless.<br /> &bull; In Mac OS X, a simple AppleScript can be used to play a movie in full-screen mode. Since version 7.2 the QuickTime Player now also supports full-screen viewing in the non-pro version.<br /> Would you like to convert your favorite DVD movies to your QuickTime formats, either for backup or for playback in case of carelessness scratch? Do you want to play with QuickTime, or to put DVD movies to iTunes, iPod, iPhone, iPad? In such cases, you need to convert DVD to QuickTime movie files on Mac firstly. Now the following steps will show you how <a href="http://www.dvdtoitunes.net/dvdtoitunes-guide/convert-dvd-to-quicktime.html">convert DVD to QuickTime</a>.<br /> Step 1: Import DVD Movie.<br /> Click "File" in menu list or "Open DVD" button, you are allowed to load DVDs from DVD Rom/Folder (data DVD)/IFO/ISO files respectively. Batch conversion is supported here, so you can add several files to enjoy the fast conversion speed.<br /> <img src="dvd-video-converter-2.jpg" /><br /> Step 2: Choose Output Format.<br /> Go to the "Output" panel. Click the "Profile" drop-down list to choose the output format. To convert DVD to QuickTime (.MOV), choose "QuickTime Movie (*.mov)" if you want to convert DVD to video file for viewing on QuickTime player.<br /> Step 3: Start Converting DVD to QuickTime.<br /> After making all necessary settings, click the "Convert" button to start to convert DVD to QuickTime (.MOV). After choosing a profile, you can adjust parameter values in the "Settings" tab, such as "Bit Rate", "Sample Rate", "Duration", "Start time", etc.<br /> More Related Guides: <a href="http://www.dvdtoitunes.net/itunes-to-dvd.html">how to burn a dvd from itunes</a>, <a href="http://www.dvdtoitunes.net/videotoitunes.html">free youtube to itunes converter</a>, <a href="http://www.dvdtoitunes.net/download-free-video-to-itunes.html">free videos for ipod touch</a>.<br />
on May 31, 2011 | Computers & Internet
Tip
How to Export Movie from Final Cut Pro (FCP) to FLV? After editing your own...
After editing your own movies on Final Cut Pro or Final Cut Express, you may want to put them on your website for presenting your introduction or promoting your services/products. For users with the older version of FCP, FCE or iMovie, it is easy to export FLV by choosing File > Export > Using QuickTime Conversion. However, if you could not find Flash FLV as output format from FCP/FCE/iMovie, you may need a FCP to FLV converter to get Flash videos.
Aunsoft Video Converter for Mac is the best FCP to FLV converter for you to handle videos on iMac/MacBook Pro with Snow Leopard or Leopard. The Mac FCP to FLV converter supports loading .3gp, .m4v, .avi, .dv, .flc, .mp4 videos from FCP/FCE/iMovie and converts FCP movies to FLV as short film. Below are the steps to export Final Cut Pro movie to FLV with Aunsoft Video Converter for Mac.
Step 1. Load Final Cut Pro movies to Aunsoft Video Converter for Mac.
After exporting movies from Final Cut Pro, run Aunsoft Video Converter for Mac as the Mac FCP to FLV converter, and click the "Add" button to load FCP short films for conversion.
Step 2. Choose FLV output format.
Click the "Format" option and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. This format is compatible to most machines.
Step 3. Transcode FCP movies to FLV.
Click the "Convert" button under the preview window, and the Mac FCP to FLV converter starts converting Final Cut Pro movies to FLV for playing on webpage.
Tips:
1. After converting Final Cut Pro movies to FLV, you need Flash players to navigate the video playback on webpage. You can use free web players like JW player, Moyea PlayBox player and Flow player to present your short films on website.
2. You can set the video resolution of the FLV videos by clicking the "Settings" before conversion.
3. The above step-by-step guide with Aunsoft Video Converter for Mac also works for the movies exported from Final Cut Express and iMovie. In other words, you can also convert FCE movies to FLV, iMovie videos to FLV on Mac OS X.
on Jul 22, 2010 | Cell Phones
My computer is mac OS and I want to cut some AVI video
How to Convert AVI to MOV on Mac OS X Lion
You might have many AVI files, either from digital camcorders, like Cannon, shared from a friend who has a PC or downloaded from the Internet, stored on your hard drive. And Apple has reported that "Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format" is playable on Mac and iOS devices. But if your AVI files are happened to be other AVI files instead of those usable ones, e.g. they are encoded with a codec that QuickTime can't recognize, like DivX, XviD, in these cases, if you want to add these AVI videos to iTunes for organizing, edit AVI in iMovie, or playback on your iPad, iPod or iPhone, etc., you need to convert AVI to MOV or other iOS and Mac OS compatible formats.
If you have QuickTime Pro installed, you can convert AVI to MOV Mac directly. Just choose MOV as the output format by selecting "Save as". If you don't have QuickTime Pro installed or QT pro can't convert the AVI successfully, you can use this professional yet easy to use Video Converter for Mac to do the AVI to MOV Mac converting task. This Mac app enables you to convert any video or audio in all popular formats with ease.
http://download.iskysoft.com/cbs_down/video-converter-intel_full139.dmg
Double click the .dmg image to install the AVI to MOV converter Mac and follow the step-by-step tutorial:
Load AVI videos to the Mac AVI to MOV Converter To do so, you can directly drag & drop AVI files to the AVI to MOV converter for Mac. Or you can head to the "File" menu, choose "Add Video Files" to locate the AVI files into the software.
Batch conversion is available, so you are able to add more than one file at one time. By the way, if you wanna combine several files into one for better enjoyment, you can choose "Merge into One File" at the bottom of the main interface.
2 Select "MOV" as the output format Now you need to choose MOV format from the format drop-down list as the output format.
mov.png If you want to put the output MOV files on your iPad, iPhone, iPod, Apple TV or other popular portable devices for playback, you can choose the presets for iOS devices offered in the format drop-down list as the output format. Because the app has optimized the video settings for the output files, so the video could fit on your devices perfectly. What's more, if you select any item from the Apple Devices as the output format, the app could import the output video files directly to your iTunes on Mac (Snow Leopard, Lion included).
Note: The AVI to MOV converter Mac additionally offers you some useful edit functions for making your videos more enjoyable. You can split, crop, add cool effects to your media files or capture your favorite scene of the video. To learn more details, you can go to the User Guide of Video Converter for Mac.
3 Start to convert AVI to MOV Mac Hit the "Convert" button and let this smart AVI to MOV Mac Video Converter do the rest for you! This video converter was specifically designed for Mac OS users. It performs greatly on iMac, Mac Pro, MacBook, MacBook Pro, MacBook Air either with Mac OS X 10.5 Leopard, Mac OS X 10.6 Snow Leopard or Mac OS X Lion.
When the conversion is done, you can play the output MOV videos in QuickTime, edit them in iMovie, Final Cut Pro, or put them on your iPod, new iPad 2 for playback whenever you like. It is cool, right? Have a nice media experience then!
Sep 18, 2011 | Computers & Internet
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I purchased WebPlus X2 last year. I recently purchased a MacBook Pro. I need this software for a Mac. Can you help?
Serif's website says that the system requirements for WebPlus X4 (apparently X3 is no longer current) are:
  • Pentium PC with DVD/CD drive and mouse
  • Microsoft Windows® XP (32 bit), Windows®Vista (32 or 64bit), or Windows® 7 operating system
So the first thing to note is that there is no Macintosh version of the software.
That having been said, given that you own a MacBook Pro, you can install Windows on it, and run the software that way.For example, the product at
ComboDealDetails.aspx
includes a discounted copy of both Windows 7 and Parallels, which will allow you to run Windows 7 right alongside your Mac OS. The solution will cost you $140, but it is a very workable, very nice solution when you are forced to use PC software for a course, etc., but own a Mac.
Mar 02, 2010 | Apple MacBook Pro Notebook
Macbook not recognising new Quicktime 7.3 or 7.6
Did you download the right version of it? You may have accidentally downloaded a version Windows, rather than Mac.
Go back and download it again, and make sure that you are downloading a version for mac.
Jul 06, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Playing Flash movies pauses for 1/2 sec every 5-7 seconds
Try this technique: download one of the many free programs from the web that allows you to download the FLV videos onto your computer. Play the video that way. Look for a version that works for your MacBook. Post back your results.
Mar 05, 2009 | Apple MacBook Pro PC Notebook
Ne macbook pro locks up
Hey amandarx8,
That really is not quite enough information to go on. What version of the Mac OS are you using? What MS Office application are you trying to use? Are you running any other applications at the same time you are running the MS Office application? This info will help diagnose your problem.
But to answer your question, lock ups are NOT normal. Make sure you have downloaded and installed any updates from both Microsoft as well as Apple.
You might also try this site for help-
http://www.microsoft.com/mac/help.mspx
Jun 16, 2008 | Apple MacBook Pro Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
48 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
