Question about Whirlpool LGV4634JQ Gas Dryer
Keep blowing fuses
My large capacity Whirlpool gas dryer keeps blowing thermal fuse. What couild be causing this problem?
  • 6,784 Answers
Hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Posted on Mar 09, 2009
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
Oct 14, 2012 | Whirlpool Dryers
My dryer wont start at all. what could it be? a thermal fuse?
It could be either the thermal fuse or the door switch. You can check the door switch usually by just pressing it in and listening for a click to know that it is engaging. Here is a link to replacing the thermal fuse.
http://www.partselect.com/PS345113-Whirlpool-3392519-Thermal-Fuse.htm?SourceCode=1&SearchTerm=CEDX631VQ1&ModelNum=CEDX631VQ1
Sep 05, 2012 | Crosley CEDX631VQ Extra Large Capacity...
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
My Whirlpool Electric Duet Dryer (GEW9250PL1) will not cylce on when depressing the START Key. I hear a "relay-like" click. In diagnostic mode, when pressing Start I get 1 beep and a cod "08" on the...
It is most likely a blown thermal fuse. There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix. If you don't keep your lint filter cleaned out, you will likely get the overheating problem, causing your thermal fuse to blow.
Apr 06, 2009 | Whirlpool GEW9250P Electric Dryer
Thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Whirlpool Lgr7646eq2 Dryer
Hi thanks for the question. most times the problem is with the thermal fuse . failure is caused by clogged venting. clean all vents . the thermal fuse is located on the air duct, inside the dryer on the left , a small piece of plastic, with 2 blue wires to it . replace thermal fuse. thanks the appliance doc
Apr 06, 2008 | Whirlpool LGR7646E Dryer
Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Nov 19, 2007 | Whirlpool LEN2000PW Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
1,073 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
