Question about Refrigerators
Periodically cycles through a loud humming noise.
Cooler runs quiet 95% of the time but every few days it sounds like the motor shifts to another level and will make a loud humming noise for 5-10 minutes. It abruptly starts and then abruptly quits but is so loud it can startle you.
  • AvalancheFan Mar 18, 2009
    We are experiencing the same symptoms with our LG (2 year old)french door bottom freezer. It began with a dropping sound and a loud bang, then an incredibly loud humming or whirring sound. It quiets down a bit but the humming always seems to be present. From reading posts it may be ice build-up around the fan. Any suggestions? Thanks.
  • 6,784 Answers
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Posted on Mar 09, 2009
  • Michael Masters
    Michael Masters Mar 09, 2009
    I would focus on the actual motor as the focal point for repair.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Newer dishwasher and actuaslly says in manual do not be alarmed if you cannot hear dishwasher as it is very quiet. Well mine is the exact opposite. It is so loud. Sounds like the motor is in overload....
I would suspect there is something stuck in either your wash motor or drain pump. If the noise happens throughout the whole cycle, it's likely the wash motor, but if it only happens on start up and periodically thoughtout the cycle, it's the drain pump. The drain pumps are known however to get noiser after a few months, in which case I would have the drain pump replaced.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Buzzing Sound at Base of Unit does not go away
If everything is working as it should - the problem may be with the motor.
Either the starter is starting to fail, or it may have gotten wet. Check for leaks around the base, and be prepared to eventually replace the motor.
If you can deal with the humming, there is no reason to replace it at this time, and there is nothing you can do to quiet the noise.
Thanks for using FixYa!
Nov 02, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
357 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
