Question about Panasonic DMRES15 DVD Recorder
Remote problem what ever you press the DVD writes DVD2. i want if some one up there can help me with this problem
I had the same problem. Finally had to read the manual. The remote and the main unit work on one of three codes - 1, 2 &3. both units have to use the same code. It's easier to change the remote.
While pressing [ENTER], hold the numbered button (1, 2 or 3) for more than two seconds. Then press [ENTER]. The display on the main unit should read SET (1, 2 or 3) to tell you which one it is in.
Posted on Mar 26, 2009
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
Dmr-ez48v when you press the remote dvd2 appears unit will work but not with remote
Press and hold the [OK] and [2] buttons down at the same time for 10 seconds. The remote will begin working.
Mar 31, 2014 | Panasonic DMR-EZ48V DVD Recorder
My Sony RD-VX525 DVD Recorder got set to DVD1, is there any way to set it back to DVD3 so I can use the remote again?
On the remote press the System Menu botton when opened, press Enter and scroll down to Option and press Enter then scroll down to Command, press enter and you'll find DVD1,DVD2 and DVD3 scroll down to it press Enter set or reset your unit as desired!
May 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
Feb 20, 2010 | Panasonic DMREZ27 DVD Recorder
I cant get my remote reverted back 2 factory settings because it wont work at all because its the player is set in dvd 3 and the remote is not ....so how do i reset it if it wont work at all
If your unit is displaying DVD2 on the front panel, you will need to set the command on the remote to match the display on the unit.
Point the remote to the unit and press 2 on the remote. Them press system menu on the remote, you should be ok.
Apr 23, 2009 | Sony RDR-GX355
Cannot use remote to play dvd or vcr
Check lower portion of remote, you will notice a button having 3 command modes. set it on DVD2 and operate dvd recorder with remote.
Jan 21, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Panasonic DMR-E55 DVD recorder - 'remote DVD2' command
I had the Exact same problem, after finding nothing on the net I called Panasonic customer-Support and they gave me the information which led to the solution:
If your DVD screen reads 'remote DVD2':
Press and hold simultaneously the "2" & "Enter" buttons (for more than 20 seconds)
If the screen said remote DVD3 then you would hold "3" & "Enter"
What I found happens when this command is accepted, the DVD screen changes to display the channel & counter
e.g. "A2 0:00.26"
If the screen changes back to "Remote DVD2" this means that the signal from the remote control has been interrupted (you stopped pressing, or the batteries have become weak.)
Providing the batteries have power, try again remembering to hold the "Enter" and number displayed after DVD.
The first time I did this it seemed to take forever (more than 30secs.), but other times it's been accepted in 6 secs.
Oct 28, 2007 | Alesis MasterLink ML-9600
Sony RM-V202 control and Emerson DVD Player
the codes are 051     060      069
1 turn on dvd
2 press and hold s button
3 whilst holding s button press and release power button
4release set button
5 press dvd on controll
6 using key pad key in the 3 digit code
7 press enter button
8 point remote at dvd and try power button
9 if nothing work enter next code
if this still dont solve your problem post back and i will tell you how to do this manually hope this is some help
Oct 20, 2007 | Sony RMT-V202 Remote Control
Panasonic DMRES15 DVD Recorder Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
