Question about Bruder forklift by
I have a 2004 Komatsu forklift its LPG and it stopped. Ive cleaned the filter on the gas shutoff valve but im still not getting any propane to the regulator nor the carb
    New Friend:
Drain lp converter
Posted on Jun 16, 2014
4 Suggested Answers
  • 248 Answers
SOURCE: Komatsu electric forklift with dead battery.
you can lease a battery, or battery charger if the battery is still good
Posted on Oct 06, 2010
rickead1
  • 1998 Answers
SOURCE: AM LOOKING FOR KOMATSU FORKLIFT
www.komatsuplasma.com 1-800-70 RASOR 1-800-707-2767 have you tried calling customer service at komatsu 1-800-707-2767
or you can fill this page out and someone will contact you from customer service http://www.komatsu.eu/contact.asp please remember if you have any further questions to message me back Thanks again Rick
Posted on Jan 22, 2011
vetteman3002
  • 2299 Answers
SOURCE: My Toyota propane powered forklift
I would suggest spraying a little starting fluid in the air filter. But not much. If it starts, then it is going to tell you that it is a fuel problem. That is a good place to start troubleshooting.
Posted on Mar 03, 2011
I have a TCM fg20 forklift that here lately seems like you have to give it more gas to move . It's propane powered. Any idea what to check ? Scott
all forklifts have an isolator valve in the drive system that stops the vehicle movement if the foot is on the brake
that area of control is where I would be looking at because if the valve is not allowed to neutralize properly then it stops movement or only allows partial movement
Dec 04, 2016 | Cars & Trucks
Why does Oven soot up during use?
Are you on propane (LPG) or natural gas? I would guess that you are on propane, and that your oven has not been converted over to LPG correctly. The regulator needs to be set up for LPG, and the oven gas orifaces need to be tightened down, and the air valves opened up. If you don't know what these terms mean, then you need to contact a professional, because you don't want to monkey around with gas!
Aug 31, 2014 | Kitchen Ranges
VALVE SETTINGS FOR KOMATSU 4D95 FORKLIFT
http://biondorentals.com.au that is one place where you can find the solution of your forklift truck problems.
Aug 21, 2013 | Cars & Trucks
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
How to check fluid levels in a komatsu forklift
Go to komatsu site and download a manual.
Jan 06, 2012 | Cars & Trucks
When commected to 20 lbs tank the pilot light does not stay on; however, when connected to a 1 lb propane bottle everything works propertly. I have replaced the fuel filter, I have tried using different...
The new 20lb LPG cylinders now have what called an OPD Valve. Reconnect to a 20lb cylinder and turn the tank valve on very very slowly, This will help prevent the OPD Valve from locking up the heater's regulator. Your 1lb cylinder is not required to have this OPD Valve.
By the way, this happens quite frequently with LP Gas Portable Grills.
Jan 25, 2011 | Mr. Heater Mr Heater Portable Buddy...
Hi im a plumber/gas fitter who has been asked if i can convert a wildcat 410 (a2) ser 1983 from lpg to ng which is currently in use at a crash repair spray booth is this possible?
Yes look up the gas valve part # and find the LP kit for that model number. It will come with new pilot orifice, new burner orifices and the springs to replace inside the gas valve. Remember that natural gas is .08"wc and LP is a heavier gas it needs to be set at 11"wc .You need a manometer to check the pressure before you light it again .Did you know that propane provides more energy per unit volume than natural gas. Heat is measured in BTUs, or British Thermal Units. Propane provides about 2500 BTUs for the same volume of natural gas that only gives 1000 BTUs.
Nov 22, 2010 | Heating & Cooling
Can we convert Laars lite llg175N to propane from natural gas? If so how
You can convert this laars with a new burner tray, new gas valve etc..I have lots of customers who was the visa versa to you Natural to LPG and LPG to Natural..I offer an exchange service please see..
http://www.laarsman.co.uk
Miles
May 20, 2010 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
How is liquid lpg system set up? i have a aqua star mod.125vp that i would like to install in my home, the liquid lpg. is the part im not shure about. thanks d.r.
The lpg either cylinder or gas tank must have a pressure reducing valve which sets the gas pressure to that required by the boiler.
After that valve the piping is the same as for any gas boiler.Where the pipe goes through the wall floor of similar - make sure the pipe has a sheath to protect it from gouges and or wet
The regs - Not sure about the USA but here in UK we have comply. different regs for tank or cylinder
The lpg supplier is a good source of info
Feb 16, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Bruder forklift by Logo
343 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
Are you a Bruder Toy Expert? Answer questions, earn points and help others
