Question about Dell Dimension 2400 PC Desktop
Taking out old hard drive(40GB) need to install new 500gb I am told that my computer can only accept 200gb at a time. what do I do?
  • jeremy_stubb Mar 09, 2009
    I came online to get my ducks in a row. I'm not familiar with all this techincal stuff. My old one is currently installed right now and before I take it out of the tower I would like to know what will happen. Is there a location on this site for formating this new hard drive?
    my computer was installed with 256m at 333. I have two new 512 at 400. They are the correct pin#. When installed my computer woudn't even come on. is there a way to make these cards work? My father purchased these for me and he was told that these would work with my system.
    Master:
  • 404 Answers
Who ever told you is wrong you can take any size but why did you come online to ask this question you could've changed it and find out. if it wasnt working then you come to fixya to ask why.
Posted on Mar 09, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 09, 2009
    well you can either do 2 choices
    1. to just add the new hard drive and use it as extra space
    2. to remove the old, replace it with the new and install everything again using recovery or operating system cds.
    I recommend number 2.
    number 1 you must have a spare "which most do" a spare connection on the same cable, hook up that connection and then hook up additional power connector "just by watching how the old one is connected you can figure out this"
    normaly it will show up automaticaly when xp is loaded but if its not then go to the "add hardware"
    but dont worry nothing will happen to the system because if you're not sure you can just put everything back how it was before.
  • lotfi bouakaz
    i dont think it will work, if your original one was 333 you only should buy a 333 . weather 512mb or 1gb
    but now we're talking memory, we were talking hard drives before no?
    anyway my point is 400mhz isnt compatible with your system but a 333 mhz is.
    so return the 400 and replace with 512mb ddr 333mhz
Acer vt7500 with a s88m motherboard and xp pro The hard drive(40gb) is failing and I would like to know what I could replace it with (ie. largest size) and install xp. I do not need to save the old...
Your 40GB drive is an IDE ("Integrated Drive Electronics") drive.
The largest IDE drive ever manufactured is 500GB.
However, some motherboards do not support drives larger than 320GB.
Some disk-drives (Seagate/Maxtor) come with a CD-ROM of "tools" that enable you to copy "everything" from your "old" drive to your "new" drive.
Oct 26, 2010 | Computers & Internet
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
Computer won't detect new HDD as master when booting
You can do this!
1. Connect your 500gig drive as the slave of your smaller boot drive.
2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools.
3. Run the executable to install WD tools.
4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
Mar 02, 2009 | Computers & Internet
Computer won't acknowledge new drive as master
press delete or F2 when you turn on your pc go into setup and change the boot sequence.
Mar 02, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Panasonic DMR-EH55 Ram Drive Problem
Do you mean you want to replace the hard drive in the unit? If so, I have one of these units and I installed a new PATA hard drive and then "prepared" it with a firmware update that is available from Panasonic's website. I tried to increase the capacity by installing a 500GB hard drive, and also a 300GB hard drive, but no matter what size I put in, after I initialized the new hard drive with the firmware disc I always only had 92 hours available to me. In fact there was never anything wrong with my unit, I was only trying to increase the capacity for recording - which I was never able to do. I did find that another 200GB hard drive I tried didn't actually work for some unknown reason, but the 500GB, the original 200GB and a 300GB hard drive worked no problem every time I swapped them around. Let me know if you need the link to Panasonic's download - it's easy to find.
Jan 23, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Having problems upgrading my laptop hard drive !!!
From what I gather basically you want to copy everything off of your 40GB and put it on the new 320GB and the install correct? Why don't you do a backup (Start>All programs>System Tools>Backup to the external 500GB drive. Install the new 320GB drive and then load the operating system from your operating system disc, then restore the data from the 500GB you backed up, or am I missing something.I know it is not as convenient as cloning but sounds like you may need to do it the old fashion way..there is no good reason that the cloning software would quit reading your disc unless it's some kind of "only get one chance and throw away software".
Dec 27, 2008 | Dell Inspiron E1505 Notebook
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
Hard Drive
Yes this hard drive should work with your system. all you should take into consideration is whether the inputs and such are the same and if all the other components in your system will support the newly added part.
Jul 13, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
35 people viewed this question
Alun Cox
