Question about The Times ROYAL TC100 TimeMaster Time Clock
Time clock shows the date 3/8/2009, should be 3/9/2009
Time clock shows the date 3/8/2009, it should be 3/9/2009, but because the clock thought last Sunday was 2/29/2009. Leap day.
How do I get the date changed?
  • lmailing Mar 09, 2009
    I can't seem to change the day and date on the clock. it keeps saying that today is 3-08 Sun but it is really 3-9 Monday
  • 113 Answers
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Select CLOCK [F3].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time. Key in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.when finish Select Restart [F4].
Posted on Dec 01, 2011
  • Mario. S. Dec 01, 2011
    sorry not the right machine
  • Mario. S. Dec 04, 2011
    Right click the clock on the desktop, and choose adjust date/time. Adjust it, Done !
  • 25 Answers
Right click the clock on the desktop, and choose adjust date/time. Adjust it, and enjoy.
Posted on Mar 09, 2009
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly..... http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
check page 2
Mar 02, 2016 | Casio DW-5600E-1VCT Wrist Watch
How can I change the day? My clock is a day ahead. the date is correct
Try backing up (going backwards) with your time until the day is correct, then, add 1 (day's) date to your date (to bring it back to being correct after going backwards).
Nov 01, 2014 | Emerson SmartSet Dual Alarm AM/FM Clock...
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Mar 15, 2011 | Emerson SmartSet CKS1850 Clock Radio
How do I change the date and time on my prostar 816 plus
ENABLE CUSTOMER PROGRAMMING
 With the handset on-hook, dial #06. The display shows [MMC DISABLED].
 Dial the passcode and 1 and then press #.
At this point, customer programming is open. Follow instructions as needed.
TO SET TIME AND DATE::
Dial #55. Display shows [YY MM DD W HH MM].
Dial new information as follows:
YY = Last two digits of the year
MM = Month (01–12)
DD = Day of the month (01–31)
W = Day of the week (1–7; week begins on Monday and ends on
Sunday)
HH = Hour (use 24 hour clock)
MM = Minutes (00–59)
Dial # to set current date and time. The phone returns to normal use.
And here is the full operational manual:
http://pdf.textfiles.com/manuals/TELECOM-S-Z/Samsung%20Prostar%20816%20Plus%20System%20Admin%20-%20Specia.%20Features%20Guide.pdf
hopefully it works for you.
Aug 26, 2009 | Samsung Prostar 816 Phone
How do i change the time on my samsung prostar 816 phone?
  1. Enable technician programming mode
    • Press "#" - "PROGRAMMING" is displayed
    • Dial "20" - "MMC ENABLED" or "MMC DISABLED" is displayed
    • Dial the password (default - 1234) - if wrong password is enter "ERROR" is displayed
    • Dial "1" to enter program mode
    • Press "#"
  2. Press "#" key - "PROGRAMMING" is displayed
  3. Dial "55" - the display shows "YY MM DD W HH MM" and then the current date is displayed
  4. Enter the new date
    • YY = Last two digits of the year
    • MM = Month (01 - 12)
    • DD = Day of the month (01 - 31)
    • W = Day of the week (1 -7 day of the week begins on Monday & ends on Sunday)
    • HH = Hour (Use 24 hour clock)
    • MM = Minutes (0-59)
  5. Press "#" - new date is saved
Jul 24, 2009 | Samsung Prostar 816 Phone
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
The Times ROYAL TC100 TimeMaster Time Clock Logo
281 people viewed this question
Top The Times Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a The Times Office Equipment and Supply Expert? Answer questions, earn points and help others
