I have a Canopus ADCV110 and both the Digital and Analog lights are lit. When I press the Input Select button, nothing happens. Is this problem fixable?
  • 70 Answers
try this,
1) Test another FW-Cable.(fire-wire)
2) Test Your Camera on another comp so that DV-in still works right.
3) check the FW cable if it is a 4-pin to 6-pin cable.
also check the manual for info,
http://canopus.vo.llnwd.net/o2/unsecure/DL/ADVC110/documentation/ADVC110-e.pdf
Plz rate :)
Posted on Mar 09, 2009
  • 10,594 Answers
If you can get its schematics then it can be repaired as it is digital to analog video converter/ device..
Please check output buffer transistors on PCB.
  • 19,396 Answers
That means that the TV is on protection mode, try first unplugging the TV for a while.
  • Ginko
    Ginko Mar 09, 2009
    Try first leaving the TV power cord unplugged for some times, let say one hour or so.
    Also
    ensure that the fault is not coming from a faulty receiver box sending
    bad signal, check if you get same problem on dvd with no receiver box
    connected.
    If that does not work, and you keep having a flashing
    led on front of the TV, and tv turning off by itself after a while,
    that indicates a fault condition.
    The flashing light indicates a diagnostic state called protection.
    When the Monitor goes on protection there are only two possible causes.
    1The
    internal circuits are jammed because of electrostatic
    chargesaccumulating on capacitors, or because of a wrong voltage read
    by themain chip on your monitor controller board. this started the
    protectioncircuit.
    2 The protection circuit detected a wrong
    voltage or abroken contact, identified an internal fault and kicked in
    , startingthe flashing light.
    If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
    If you are in situation 2 , then there is an internal fault.
    Common faults
    that can occurr are a blown capacitor on power board, a
    convergence IC has blown, or a fault on Digital board.
    Check also
    the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
    can get same flashing statebecause of the video cable.
    Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
    If under warranty contact the manufacturer ringing the number on the user manual
    If you want to repair at your own expenses, just locate any good qualified repairer.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
My Canopus ADVC-110 has both input light on and I
The problem got no free response so I ordered a new unit.
Jan 02, 2010 | Canopus ADVC-110 (77010150100) Video...
Can I use the Canopus Twin Pact 100 to transfer vider from digital video camera to computer? The firewire port on the camera is no longer working, so I need another way to transfer the video to the...
No, it isn't really the right tool for the job.
The Canopus is for converting analog video signals to digital (like capturing the video from your computer monitor as you move the mouse around).
You already have a digital video source (your digital video camera). So this box won't accept that as input.
If your video camera has other output ports, like component video (see below for a picture), then it might work. The Canopus will accept analog RCA for input.
Mar 12, 2008 | Cameras
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
RCA STAV-3880 RECIEVER FOR CHEAP. I DOES NOT RECOGNIZE DIGITAL
I have found that on some units you unfortunately need the remote for more advanced settings. Sorry man.
Aug 01, 2009 | Audio Players & Recorders
"no device control" blue screen on imovie with ADVC55 connected
Hi - The red light indicates the VHS is Macrovision copy protected, so the ADVC55 is refusing to import it.
There is a sort of "secret" workaround for this that most people who own the old Canopus products know, and which Canopus also knew, supported, and had posted on their forums (unfortunately deleted by the new owner who seems to be unclear on copyright law).
Remember, it is LEGAL to make ONE (but ONLY one) copy of any copyrighted material for your personal use for backup purposes. In other words, if you do this, you can record the movie into your computer and store it there, or burn it to a DVD (after which you must erase the copy on your computer), but that's all! You cannot make another copy for anyone else - not even yourself - without violating copyright law.
That said, here are the two procedures that usually work, easiest first:
1) When you first turn the Canopus on, hold the select button down for roughly twenty seconds. Now the system should ignore any copy protection until you turn the unit off.
2) (if 1 doesn't work:)
1. Put all dip switches OFF (unless you have a PAL system). 2. Hook up the firewire cable from the unit to the PC while ensuring that both units are OFF (this is what the instructions say to do, because you can cause a damaging power surge otherwise).
3. Turn on the power to the DVD player, PC and ADVC-100.
4. Set capture on your PC (your software) to Manual.
5. Start the DVD.
6. The ANALOG IN LCD of the unit will light, and if the DVD is Macrovision protected, the red STATUS light will stay on for about 18 seconds, turn off for about three seconds, and then repeat the process (or may remain red longer on some units).
7. Depress and HOLD the INPUT SELECT silver button. The DIGITAL IN LCD will light up temporarily then turn off. Keep this button depressed until the red STATUS light stays off completely (about 15 seconds).
8. Release the INPUT SELECT BUTTON and press it briefly one more time until the ANALOG IN button lights up.
9. Macrovision is now bypassed!
Again, once you turn the ADVC55 off (which you must - if it stays on for long periods it can overheat and malfunction), you'll have to go through the Macrovision bypass procedure again next time you turn it on.
Good luck, and I hope this works for you as it did for me with my Canopus!
Jul 09, 2009 | Canopus ADVC-55 Video Capture
Analog and Digital selections lit up, status light flashing
Although you are using another 5v cable, please make sure that the AMPS are correct. Look on the back of your Canopus and see if it lists the amps along with voltage. Too liitle or too much a,perage will cause malfunction.
Jun 23, 2009 | Canopus ADVC-110 A/D Converter...
No analog signals thru ADVC100
Canopus customer support just wrote me back with the bad news: "If all 3 lights are on, then the unit has failed. We no longer
manufacture or repair ADVC 100's (they are almost 7 years old now). You
would need to purchase the newer ADVC 110 as a replacement."
Dec 12, 2008 | Canopus ADVC100 (77610072100) Video...
Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
May 07, 2008 | Canopus ADVC-110 A/D Converter...
Switch from Analog to Digital
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
(1)(4)(4)(1)(4)(1)
I hope that helps
toypaj
Mar 18, 2007 | Matrix HANNSFREE 19 Analog and Digital...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
