My washing machine is in the middle of a cylce and then it stops and the on/off button flashes and the reduced creases and mini load buttons are also flashing. I have tried switching the machine off by on / off button but it still flashes, I have also tried to switch it off at the wall and then switching it back on again to release dool lock but this isnt working (there is no water in the machine) Many thanks
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How do I set my hotpoint ultima to English language
turn it OFF (seems like the wrong thing to do but do it anyway) then press and hold the 3 middle buttons under the display panel until you hear a beep - they are labelled reduced creases, mini load and time saver. When you switch it on again you get the language menu. There are 4 buttons either side of the display - the right 2 scroll through the languages and the top left one sets it once you've found the English setting. Guten Tag!
Jun 21, 2015 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint washing machine wf340 will not complete a wash cycle it just stop then the lights start flashing next to the mini load button + reduced crease button and the on off button pls help
You have a bad printed circuit board (PC board). You will have to replace. I would rate this job a 4 on a hardness scale from 1 to 10. You will need your model number located on the back of the console toward the top. Go to this site and enter your model number. You can order it with a credit card 24/7 http://www.partselect.com/
Please rate this solution if helpful.
Aug 20, 2009 | Washing Machines
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
