Question about Mtd Garden
Riding mower goes slow in forward speed
I put new belts on my mtd riding 38 inch cut with a briggs 12.5 motor and if I go up a hill it just comes to a stop and the belts stop turning as well as the pulleys. I can see this as the shifter cover is off and I have to depress the clutch and release it again and it takes of but instantly go very slow. I have adjusted the threaded rod nut that goes to the speed shifter but it still goes real slow. It was going slow before I changed the belts but I was hoping this was what the problem was. It runs great and mows great it is just very slow and takes a long time to mow.I checked the pulleys when I had the belts off and they spin freely. It goes slow with or with out the blades engaged.It used to go real fast and then started slowing down and if I push and release the clutch It would pick up a little and start going slower again.Please help me thank you.
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Posted on Jul 14, 2014
rockitman187
  • 2559 Answers
SOURCE: leveling the deck
You can go to this link and look at page 24 It is the same for almost all mowers.
Please take time to rate this fixya
Posted on May 12, 2009
scott586
  • 41 Answers
SOURCE: launch on take off
I have the same problem sometimes, but it is only when I let the brake / clutch out fast. When you go to let the clutch off, and you are in gear. Try easing off on throttle, you can increase the throttle after the clutch is out. THis should help with you sore neck. Another thing you may want to try is adjusting the throttle calbe. It should show or tell you in the manual how to do this,
Posted on Apr 24, 2009
  • 59 Answers
SOURCE: Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
Posted on May 27, 2009
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
RonInFla
  • 86 Answers
SOURCE: mower stopped dead. blades go, tractor starts and
broken drive belt
Posted on Apr 28, 2010
What sizes are the drive belt and mower belt on a 1999 agway mtd riding mower with a 12.5 hp briggs?
go to any lawn mower shop they will tell you and get you your belts 45.00 to 60.00 for a belt
Aug 11, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
How to put on driver belt for a MTD 38 inch cut
Your owners manual should have instructions for changing belts. If you need a manual, go here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Aug 05, 2009 | Mtd Arnold Corp 38" /42" Mulch Kits
Describe your Poulan 38-Inch Steel Deck 15.5 HP
Go to this site:
http://www.mowerpartsweb.com/manualindexasp.asp?manu=POULAN&Submit2=Submit
Download the manual and it gives a good clear picture of how the belt is supposed to go on.
Jul 17, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
How to put deck belt on
need a diagram of how to put a deck belt on a 15.5 hp/38" cut 5 speed poulan lawn mower model number 9601200-3801
Jun 22, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
2,593 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
