Question about Hitachi 43UWX10B 43" Rear Projection Television
Pioneer SD533HD5 Convergence Issue
I am wondering if anyone knows the values of the resistors that I would need to get in order to fix the problem myself? Can I simply pick up the Hitachi x480301 repair kit?
  • Hitachi Master
  • 3,459 Answers
All the values and resistors are part of the Hitachi kits on www.TvRepairKits.com
Posted on Apr 08, 2010
July 27, 2012 Picture appears like I am using 3 D glasses, with red Does anyone know my problem. Good set no issues until now. Dave B.
try to adjust in the set up menu color convergence adjustment. if can get with the adjustment then you may have bad convergence IC or resistor in the convergence circuit.
Jul 27, 2012 | Pioneer SD-P50A3-K TV
Hitachi 61swx10b HDTV - Convergence problems. User 'gdroukas' mentioned in a post that it is probably the convergence amps and a few resistors that have changed value. Can anyone be a bit more specific? ...
Convergence ICs are Big Black ICs and will have the part number on them. STK392-110,
upgrade to 120s or 150s better ICs.
Resistors to replace are RK42 3.3ohms, RK46 1.8 ohms, RK50 2.7ohms,RK54 1.5, RK58 3.9 ohms. RK62 2.2ohms
Mats Electronics has STK ICs 1-800-628-1118 order convergence Kit that comes with resistors.
ACME has the Convergence resistors they must be 1 watt resistors 1-800-575-9833
Let me know if you need any more help Thank You.
Jan 13, 2011 | Televison & Video
Need Circuit Diagram, or convergence resistor list for PT51D31CE
they are 2.2 ohm , i have replece many of this before
Apr 19, 2010 | Panasonic PT-51D31 TV
How do I locate resistor values?
Click HERE to download service manual copy for free. Download all 12 files and unzip with winrar to get pdf file.
Hope this will help you to find out required resistors value.
Oct 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
HCN4727W Convergence issue
Repalce STKs with 392-040 resistors should be 3.9 ohms,also you might want to join Repairworld it is for members who have TV shops over 7,000 different shops / lots of good techs there.They will not put up with anyone just looking to repair there own tv .Sorry unable to help with cz140,141.will do some checking you also can order whole convergence board.
Sep 08, 2008 | Samsung HCN4727W 47" Rear Projection...
Toshiba 57H82 resistor value???
When I get to work in a few hours, I will get the value for you.
Yes,you can use a regular 1/4 watt resistor and you might be
able to measure the value of it's twin in the other IC circuit....T.
Jan 21, 2008 | Toshiba 57H82 57" Rear Projection...
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
TV shuts off seconds after being turned on
This is actually a common problem with this unit and one that Pioneer is aware of... Over time the feed resistors in the convergence circuit change in value and the convergence ICs begin to fail, placing more of a load on the power supply than necessary and stressing components in the SMPS. The fix; Pioneer recommends upgrading the convergence IC's from STK392-110 to STK392-180, change all resistors in the convergence circuit that have changed in value and replace the power supply to repair the unit.
Jun 27, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
