Question about Xerox Phaser 8560DN Laser Printer
Phaser 8560 magenta ink not transfering to paper
I;ve got an 8560 dn where the magenta ink only is not transfering completely from the drum to the paper. The maintenance kit is new and working well. the Ink is NOT xerox. how do i remove all the inksticks and replace with xerox... I've learned my lesson. I;ve got an 8560 dn where the magenta ink only is not transfering completely from the drum to the paper. The maintenance kit is new and working well. the Ink is NOT xerox. how do i remove all the inksticks and replace with xerox... I've learned my lesson. Yes this exactly the same as jbassett285. The standard cleaning nor replacing the Maintenance Kit helps. Someone must know of a complete cleaning process. The machine history is 12 mo old and 22,000 prints (12,000 in color)
    Genius:
  • 1,550 Answers
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Source:fixyouownprinter.com
Posted on Mar 09, 2009
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Aug 11, 2013 | Xerox Phaser 8500/DN Printer
Keeps asking for ink and it has ink
Try removing, and then reseating the MAGENTA cartridge.
If you replace the MAGENTA toner-cartridge, does the problem go away?
Jul 30, 2010 | Xerox Phaser 8560DN Laser Printer
Does phaser 8560 and 8500 take same ink
The 8500 and the 8550 do use the same solid ink cartridges. Not sure about the 8560 since couldn't find information about it.
Jun 24, 2010 | Xerox Phaser 8500/DN Printer
Patchy color printing, streaks and dull colors using Phaser 8200
I have the same exact problem. I just switched to a mac and the colors are awful. I tried from 3 different macs at work, trying different combinations of color profiles, settings, etc, and the colors always look completely off. Blues are magenta, bright red is a dull reddish, orange is completely brown. It looks like Xerox decided to not even try to make this aspect work with the Mac. This is on the latest Mac book Pro, running Snow Leopard, to a Xerox Phaser 8560 DN.
Jan 05, 2010 | Xerox Phaser 8200 Laser Printer
Error code 09,036.44:34979 What does this mean and what can I do to resolve it?
Oct 23, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Hi jbasset285: Your printhead may be bad do to third party ink.
follow these steps:
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 8560 DN is jamming in same place every time.  I remove paper and it re jams in same place.  Now printer is making a loud gear slipping noise.
There is mostlikey a scrap of paper that you can not see still in the machine. You can gently walk a thicker piece of paper through the paper path and see if it pushes out the obstruction. Be very careful not to scratch the drum when you try this.
Hope this helps
Nov 26, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
80 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
