Question about Ricoh Aficio 1013F Copier
Ricoh 1013F Fax Line answering phone calls
I have a ricoh 1013f set up on a single line with faxes being two rings and phone calls being one ring. There are two numbers one fax/one phone. But this machine will pick up every call fax or phone. How can I get it to only take faxes?
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Posted on Mar 09, 2009
"user tools", scroll to....."fax features", scroll to "setup", scroll to "no. of rings"
Set the appropriate number of rings to not conflict with Voice mail, etc...usually 4 will do, but just test the phone and fax after you set it up, to make sure it is ok. You can test it by calling it from your cell phone, or a land line (on another line), in other words, you don't have to wait for a fax, just dial the fax number and see when the fax picks up, then try the phone number etc.
Is it possible ot add the printer function to a ricoh 1013F Super G3 copier/fax
I think that it is not possibel.
But the question is: If it was, Is it viable???? The money you are going to spend worth it????
Feb 17, 2011 | Ricoh Aficio 1013F Copier
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Fax header Ricoh 1013F
GEEZ, the 1013f, I beleive you have to access the user tools buttom, it is on the left side of the control panel. From there slect fax features, then select general/settins adjust, then program fax information, then slect fax header, from there you will use th alpha keys on the left side that double as the one touch keys. When you are done select ok!
http://copierquestions.websitetoolbox.com/
Aug 13, 2009 | Ricoh Aficio 1013F Copier
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
How could I switch the fax, to receive
do you mean the fax line is shared with the phone line, and you want the machine to pick up faxes when necessary, and let phone calls go? If that's the case, this mahcine is designed to be on a dedicated line. In other words, there is not setting for "distinctive ring", or to set the # of rings to pick up. It will answer any call coming in. The only thing you can do is set it to "manual receive", under "user tools", "fax features", and then you could use it for sending faxes, but it will not receive unless you switch it to fax, and press the "on hook" button.
Jun 12, 2009 | Ricoh Aficio 1232C Color Copier
Faxing instructions
press fax button. on hook dial, number with the keyboard, place the original on the cristal, pres start, after all pages has been scanned press # or take the phone, place original, mark the number on the phone when you hear the signal press start.
Nov 11, 2008 | Ricoh Aficio 1013F Copier
Ricoh Afcia 1013F Need to change Modem Speed for Use with VoIP
That fax modem isn't compatible with VoIP. You need a seperate analog phone line to get it to work.
The maximum baud rate for faxing on that machine is 9600kbps.
Oct 15, 2008 | Ricoh Aficio 1013F Copier
Changing the number of rings on fax.
Press the "User Tools/Counter" button at the control panel.
Under the display, press the "Right Arrow" button until the display shows "4. Fax Features" & press the "OK" button
Press the "Right Arrow" button until you display "3. Setup" & press "OK".
Press the "Right Arrow" button until you display "5. No of Rings" & press "OK"
Enter # of rings with numeric keypad & press "OK"
Display will briefly show "Programmed"
Press "User Tools/Counter" button to exit back to regular display
Jul 08, 2008 | Ricoh Aficio 1013F Copier
Ricoh fax/copy machine
Instructions for 1013F are as follows:
above the blue numeric keys 2/3 there is a button with a small box with 123 in it this takes you in and brings you out of the USER TOOLS MENU.
Press user tool button once...user menu on display
use right arrow key...press3x..Fax Feature..press ok
right arrow2x..ok
again right arrow2x.ok....DATE/TIME on disply .ok
change then ok it once done exit by the 1st button you started with...USER TOOL BUTTON. all the best....
Mar 28, 2008 | Ricoh Aficio 1013F Copier
390 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
