Question about Ricoh 3310Le Fax Machine, FAX3310Le Printer
Fax not received
Caller said fax was sent but we did not receive. Does a 3310Le store an image sent by an outside number? If so, how do we pull up the document and print?
  • 2,120 Answers
No, just the fax phone number.
Posted on Mar 10, 2009
I have new canon pixma mx 328. how to do fax operations of sending and receiving
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Dec 14, 2010 | Canon PIXMA MX300 All-in-One Printer
I need to verify a received fax, but the connection tel column is blank (there is no number shown). How do I see who sent the fax at that time. There is a transaction number.. but how do I match this with...
It's possible that the originator has their number blocked (caller ID blocking). If that line is only used for the fax, I would try to learn the number using that same line and then using a phone, dialing *69 (in our area, yours may be different). If your service operates the same, you should get a voice message with the number and an offer to dial it for you.
Jul 15, 2009 | Canon LaserClass 2060P Plain Paper Fax
My office fax machine can receive the fax in the memory, but it does not print it.
May 19, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:;f=17;t=412
Jan 02, 2009 | Symantec WinFax Pro for PC
Date and time stamp
Here's the instructions for the date/time stamp.... I'll check on no. of pages and post that too.
Press the 'User Tools' key.
Use the right/left arrows until '2. Fax Features' is displayed.
Press the 'OK' key.
Press right/left until '4. Key Op. Tools' is displayed
Press 'OK'
Press '2222'
Press 'OK'
Press right/left until '7. User Parameters' is displayed
Press 'OK'
'1. Change' should be displayed - Press 'OK'
Now 'Refer Op. Manual: Switch 00 :xxxx xxxx' should be displayed; use the right/left arrow until 'Switch 02 :xxxx xxxx' is displayed (xxxx being a bunch of 1's and 0's).
When 'Switch 02' is displayed, the third digit from the RIGHT should be a 0. Press the '2' key, and that digit should change to a 1.
Press the 'OK'' key.
You should be back at the 'User Parameters' menu - just press the 'User Tools' key to return to the standby display.
Presto, try it out!
Please rate if this helps :)
Mar 26, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
Intermittent problem of faxes not being rec'd from various areas
After a detailed discussion on chat, we got disconnected before accepting payment. This is not a problem with your fax, as it seems to be receiving most calls fine. I suggest printing out a report - Menu/Set, 2, 0, 2 - of caller ID history and having the phone company look into it further. Either there is a problem with your phone line, or someone is prank calling your fax from outside of your caller ID service area. Both are problems for the phone company to fix.
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
106 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
