First make sure that the mixer is plugged into a working outlet. Were there any symptoms the last time you used your mixer? Check the cord on the mixer for damage. If the cord shows any wear replace it immediately.
At any point in time have you removed the brushes or adjust the speed control plate? After checking the cord, remove the brushes from the mixer, check to see if they are pitted, if they are replace the brushes. Please pay extra attention when putting the brushes back in the mixer, there is a dog-eared side of the brush, match this up to the brush holder to make sure the brush is inserted correctly.
If the brushes are not the problem check the speed control plate. If you remove the end cover from the mixer you can gain direct access to the speed control plate. There are 3 screws on this plate, the top two are used to adjust the speed of the mixer, the bottom one spaces the on/off switch contact. Try adjust the bottom screw to see if the mixer will turn on, it is possible the on/off switch was out of place.
Try these first, if none of this works let me know and we can continue trouble shooting.
Here is a link to the cord for your mixer: http://www.mendingshed.com/mixercord2.html
Here is a link to the brushes: http://www.mendingshed.com/kitchenaidbrushes.html
Here is a link to the speed control plate: http://www.mendingshed.com/speedcontrol.html
And here is a link to the service manual for your mixer, it has more troubleshooting ideas on the last few pages: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
[email protected]
800-339-9297
SOURCE: kitchenaid ksm90 problem
Check the mixer's accessories, these should be fitted well. Also check the mixing tool it should be aligned properly so it won't rock.
Hope this FIXYA the problem.
Post me back if it doesn't.
SOURCE: KitchenAid 300 Watts KSM90 Ultra Power sparking
Sparking is a safety concern and Kitchenaid will see it as such. I would suggest calling Kitchenaid Customer Service. They are likely to exchange the product, regardless of warranty or age, because of the potential safety concern.
Their toll-free telephone number is 1-800-541-6390.
Please confirm the full model number and download the manual from the list on the link below.Click on selection to download.
shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KSM90&siteCd=KAD&userType=Consumer
Hope this helps.Thanks.
