SOURCE: Radio not working
Have you made sure your power source has power?
Next check your inline fuse if it has one.
Make sure you do have a good ground.
If none of these solutions work you most likely have a bad system.
SOURCE: need colour coding for wiring back of radio
black= ground
blue= antenna
red= power ingition
yellow= 12volt battery
blue\white= amp turn on
SOURCE: find remote wire connection for sony cdx ca400
Should be a blue wire with a white stripe in the plug that goes into your unit if its missing take the harness to bestbuy or an audio shop and they can prolly stick a wire in the empty spot. hope this helps you.
SOURCE: i have a sony cdx-f5000. i recently purchased
Block 3 in this diagram refers to a Source Selector XA-C30 and Buss Control signal from same device.
http://www.docs.sony.com/release/CDXF5000install.pdf
And here is a link to your Sony CDX-F5000 Operating Instructions.
http://www.docs.sony.com/release/CDXF5000.pdf
SOURCE: Hi, I owned a Sony CDX-GT820IP. I had it installed
the blue white wire is the remote on for amplifiers
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
