Question about HP Officejet Pro L7680 All-In-One Printer
Lost startup disk new computer Mac want to go wireless
My wife took the start up disk to work and that's the last I have seen it I just got a mac laptop and I want to print wireless and I need a disk or what ever to make it happen.jl
    Genius:
  • 1,605 Answers
Go to hp.com, click on serivces and support.
input your model number and dowload the driver and software you need
Posted on Mar 09, 2009
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
HELLO
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA https://plus.google.com/u/1/116937682228750782866 APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Hi,\r\ni have a problem with my macbook air when
Try restarting your computer while holding down the X key. This may force the computer to start up using your Mac OS X system. If it does, release the X key, then open System Preferences and click Startup Disk. Make sure your Mac OS X system is selected. If you are unable to start up using the X key, restart your computer and immediately press and hold the Option key. Release the Option key when icons start to appear in the center of the screen. Select the Mac OS X system disk, then click the forward arrow to continue starting up.
If the above attempts to reselect your Mac OS X startup volume are unsuccessful, try resetting PRAM. Shut down your computer, then turn on the computer and immediately press and hold Command-Option-P-R until you hear the startup sound for the second time. Open System Preferences, click Startup Disk, and select your Mac OS X volume.
Hope this helps. If none of these options fix your problem, bring your computer to an Apple store, they are always very helpful and almost never fail to fix the problem!
Mar 11, 2011 | Apple MacBook Air
I've been scanning to my computer w/ my cannon mp240 and suddenly cannot. It still scans and prints and prints from my computer, but the scanning to computer has stopped. I have a MAC and it's worked...
The printer drivers for the MP240 are intergrated in the Mac OS X.
If software for your printer was included with the Mac OS X installation, check the printer manufacturer's website for updated versions. Install a printer driver available from the manufacturer's website only if it is a newer version than the one included with Mac OS X.
Repair disk permissions
Tip
: For more information about Repair Disk Permissions and Mac OS X v10.2, v10.3 or later, see "About Disk Utility's Repair Disk Permissions feature".
  • Mac OS X v10.3 or later: Open Disk Utility (/Applications/Utilities/). Select your Mac OS X startup volume in the column to the left of the Disk Utility window, then click the Repair Disk Permissions button.
  • Mac OS X v10.2 through 10.2.8: Open Disk Utility (/Applications/Utilities/). Select your Mac OS X startup volume in the column to the left of the Disk Utility window, then click the First Aid tab. Click the Repair Disk Permissions button.
  • Mac OS X v10.1.5: Update to Mac OS X 10.1.5 if you have not already, then use the Repair Privileges Utility. See "Mac OS X: About the Repair Privileges Utility 1.1".
Reset printing system (Mac OS X v10.4 and later)
If other steps haven't helped, you can reset the printing system. Important: This should only be used as a "last resort" when troubleshooting a printing issue.
Dec 17, 2010 | Canon Office Equipment & Supplies
When powering it up it starts to boot I get a blue screen then it goes black where do I start ?
Try starting your mac from it's install disc.
1) First turn off your computer.
2) Then restart it, right when you push the power button to turn it on, press the option key down and hold it
3) pressing the option key will bring to a screen where you can choose your startup disk. Usually, you'll see your Macintosh HD available to startup from. Don't choose anything yet.
4) Insert your install disc into the CD slot.
5) wait a couple of seconds and then clock on your install disc as your startup option.
6) after clicking on the disc, go to the menubar and click on Utilities then disk utility.
7)once the disk utility app is open hit "verify disk permissions"
8) after you've "verified disk permission" hit "repair disk permissions"
- this might take a long time depending how much you've actually done this (which it's good to do every other month or so to keep your mac running smoothly). things might seem to freeze up as well, but it's the mac trying to verify and repair broken permissions on your computer. Don't that's normal.
9) after you have repaired the disk permission, reboot your mac by quitting disk utility and then choosing the startup disk as your normal macintosh HD. That should do the trick. If not, tell us what has changed.
Dec 15, 2010 | Apple PowerBook G4 Mac Notebook
I forget username and passowrd in my MAC OS X Version 10.4.11,please findout the solution to restore my username and password.....
Did you lost the administrator password? There is a way to reset it. You will need the install disk in the resetting process. Please make sure you follow the steps accordingly.
From Mac OS knowledgebase:
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue, then choose Reset Password from the Utilities menu (or from the Installer menu, if using Mac OS X 10.3.9 or earlier). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  3. Select your Mac OS X hard disk volume.
  4. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  5. Enter a new password.
  6. Click Save.
Sep 04, 2009 | Apple Mac OS X 10.4
Weird Folder Thing
It may be just a desktop folder which you would use to continue an installation, you should delete and start again.
Feb 28, 2007 | Apple iMac G3 (1999)
HP Officejet Pro L7680 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
