Question about Panasonic Genius Prestige Nnsd997s Inverter Microwave Oven 1200w Stain
Panasonic inverter 900w microwave fault code h97
Shuts off after a few seconds and displays H97
  • leonard ortiz Aug 17, 2013
    how do i fix it or what needs to be done to fix it? can it be saved?
  • Pamela Wright
    Pamela Wright May 07, 2018
    I am getting the H97 error message. Is it worth repairing?
  • Panasonic Master
  • 9,156 Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Apr 16, 2013
    Problem Solver:
How does this happen?
Posted on Oct 04, 2015
SOURCE:
Midwest-Tek
  • 864 Answers
SOURCE: code H97 on panasonice inverter
H97, mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these. Thanks, Midwest-tek
Posted on Aug 31, 2010
seanpwright
  • 2030 Answers
SOURCE: microwave stopped working suddenly,the sreen reads H97
If your oven is out of warranty then i would suggest just getting a new one.
The code is for a bad controller circuit, and it would cost almost as much to fix it as it would to buy a new one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Jan 12, 2010
  • 8909 Answers
SOURCE: My Panasonic NN-ST657W microwave has
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Posted on Dec 31, 2010
Testimonial: "That's what I was dreading. Might be cheaper to buy a new microwave than to have a new magnetron put in... sucks only 3 yrs old. Thanks anyway."
rickead1
  • 1998 Answers
SOURCE: Panasonic Microwave Oven showing error
here is the link of how they troubleshoot this code they do not advise anyone to perform this test unless you know how to discharge the capacitors and there is also an extremely hi amount of electricity it might be best to call a service tech but you can have a look at the link usually that error pertains to the magnetron or the invertor haveing an issue http://www.applianceaid.com/micro_faultcodes.html
if you have any further questions message me back Thanks and please remember to rank how this opinion has helped it allows me to help others in the future in similar situations Thanks Rick
Posted on Feb 13, 2011
ginko
  • 19396 Answers
SOURCE: My Panasonic microwave Genius 1250
Is a fault in the power supply, usually a faulty inverter.
Here explains how to diagnose and fix it.
You may need to call in a repairman, check the last pages of the owner manual to find out how to call service.
Posted on Jul 09, 2008
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Panasonic flatbed microwave NN-sf550W displays code H97
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jan 21, 2013 | Microwave Ovens
In the display there is H97
H97 means the magnetron and/or invertor board is faulty.
Call a Panasonic registered domestic appliance engineer for service.
There are no user serviceable parts inside your machine.
Mar 29, 2011 | Panasonic NNCF768M Microwave Oven
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
Dec 31, 2010 | Panasonic Microwave Ovens
We have a Panasonic Microwave model number NN-t945SFX. We were using our microwave as a Inveter Turbo Defroster as we prepared our meal. Seconds after, a family member decided they wanted popcorn since...
NN-T945SFX May 27, 2017
If it stops after 7 seconds, it likely has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Microwave stopped working suddenly,the sreen reads H97
Jan 12, 2010 | Panasonic NN-H275 Microwave Oven
Why doesnt my oven work?
H97 can mean that there is a problem with the Inverter Board, and you may need to take it to your local Panasonic repairer for assessment.
Mar 24, 2009 | Panasonic Microwave Ovens
Panasonic Genius Prestige Nnsd997s Inverter Microwave Oven 1200w Stain Logo
21,170 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
