Samsung 931b Monitor is red
Checked and manually/auto adjusted all color settings and no pins bent or missing from cable
Getting a good image just red Fixable or get serviced?
Thx in advance
  • 109 Answers
Loose CRT board solder or chroma ic and transistors problems..
Posted on Mar 09, 2009
My monitor is not displaying red color some...
If only ONE colour is missing - it is usually just the VGA connector that is not plugged in properly or you bent a pin while connecting the monitor to the PC.Unplug the VGA cable and look at the pins and make sure nothing is bent .. then re-insert the VGA connector properly. That should fix it.
Good Luck
Feb 04, 2011 | Computers & Internet
Red color channel is missing
Check the monitor cable for missing or bent pins. If you find any bent pins try to carefully bend them back. If they are broken or lodged in the computer or monitor plug you may have to replace the plug.
Move the cable around while the monitor is on to see if moving the cable has any effect on the color. This will indicate if there is internal damage to the cable. Internal damage will require professional repair.
If you are still missing the red channell no matter what you do with the cable the problem is likely to be in the monitor which will need professional repair.
If you want to make sure it is the monitor, not the computer, with the problem try using another monitor.
Please vote for my solution if it helps.
Feb 08, 2010 | Samsung SyncMaster 753 DFX 17" CRT Monitor
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
Screen comes on but is completely white
Make sure none of the pins on your cable are bent. If they are then even them back out so they are aligned properly, 5 pins on each of the 3 rows. If you are still getting a white screen then go ahead and try another known working monitor on your computer. If the 2nd monitor works then you know its a problem with your original monitor. If the 2nd monitor doesn't work then you know that your video card is bad and would need to be replaced.
Jun 05, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Added as 2nd monitor, color PINK
Check the cable...are any of the pins damaged, bent or missing? Can you access the Monitors control panel and reset its settings to factory default?
May 17, 2009 | Samsung SyncMaster 920NW Monitor
Hi, my monitor is "Samsung SyncMaster 793df". Problem is i can't set right color and contract. how can i solve it?
If the monitor has a consistent tint throughout, try to adjust the color through the OSD (On Screen Display). If this does not resolve the problem, or your monitor seems to be missing a color, disconnect the signal cable from your computer and wait for the No Signal image to appear. If all colors - red, green and blue - are present in the No Signal image, the problem is not with the monitor, but possibly with the video cable or video card. - exert from samsung faq....
http://ars.samsung.com/customer/ctry/jsp/faqs/faqs_view.jsp?isINPUT=Y&SITE_ID=58&PG_ID=-1&AT_ID=48749&PROD_SUB_ID=0&PROD_ID=28
If you mean something else, go into a little more detail if you wouldn't mind... Also, another thought has popped to my mind, you do have the drivers for your monitor installed?
Jan 13, 2009 | Computers & Internet
Appearance on monitor is reddish in appearance
Depending on your monitor settings, you should putt all 3 colors on either 0 or 50. whichever is in the middle of the spectrum in your settings. However, when I've seen this problem on monitors, it's been a problem with the cable. Sometimes the cable is tilted, meaning some of the pins aren't connecting. In other cases, missing or bent pins can cause this too. So try to check out both ends of the video cable and adjust it accordingly.
Aug 10, 2008 | Hyundai L90D+ 19" LCD Monitor
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Color Problem
In rare instances it is sometimes the 15 pin connector that connects on the computer end. Could be at the monitor end of the same cord, if it is a connector and not hard wired to the inside. Check both possible sides for bent pins.
I once went through an extension cable and had to remove it as it was bad connections and I'd have constant color changes drifting in and out. Sorry, but most likely it is just a cheap monitor on the fritz.
Sep 07, 2007 | X2Gen MG19MY 19" LCD Monitor
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
