Question about Canon Office Equipment & Supplies
I want to change the phone number and name that appear at the top
I want to change the phone number and name that appears at the top of the fax that I send out. I have had my Cannon Faxphone L80 for a long time and can't find the manual. I can't get the function button to work. Please help.
  • 2,011 Answers
Go to this link. Click on the link for the L80 Users Guide, and the guide will open in a separate window. Go to Chapter 3, Registering Information, and you will get directions for entering your Sender Information beginning on page 3-6.
Posted on Mar 09, 2009
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How to change phone number.
Hi
1 Press Menu.
2 Press 5, then press 2.
This selects the Basic Fax Setup menu, then selects the Fax Header option.
3 When Your Name appears, enter your name using the keypad
4 Press Enter.
5 When you are prompted, use the keypad to enter your fax number.
6 After you finish entering your fax number, press Enter.
if i help you pls vote me
Sep 08, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I'm trying to change the name that appears at the top of my fax sheets when i fax
The name that appears on the top of the fax's you send is called the TTI (Transmit Terminal Indentifier ) and should be in the basic set up instructions for your Fax machine....as it is different for each manufacturer I am unable to help further as you have not specified what make or model you have.
Sep 02, 2010 | Office Equipment & Supplies
This fax machine was donated to our school and we need to change the banner message that appears at the top of page when something is faxed.
Presss the Function button and then data registration button ,under settings you will find Tel number set your number.The next funcktion is user name, set your user name and press set.
Dec 14, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
MFC-8820D we have moved our office and have a new phone numder. How do we re program that number into our fax. Thanks matt
The following procedure will reprogram a new station (home fax number) for your machine. Thank you for using Fixya and please post back with any questions or to rate the answer provided.
Greg
  1. Press MENU 0,3
  2. Enter your new fax number (if the old still exists, move the cursor/arrow back ward to the first position to change the number displayed
  3. Press SET
  4. Enter telephone number (if it's the same as the fax number, enter the fax number again)
  5. Use the dial pad to enter your name (if your name still exists, leave it as it reads)
  6. Press SET
  7. Press STOP/EXIT
You will be given a choice to press 1 to continue with the change or 2 to exit without changes.
Press 1
The date and time will now appear and the change is complete
Sep 10, 2009 | Office Equipment & Supplies
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
85 people viewed this question
old marine
old marine
