Question about Copystar CS-1530 Copier
Ap keeps popping up can't remember what that means
    President:
  • Copystar Master
  • 990 Answers
Hello dear; Don't worry about "AP" means adding toner, machine is working on that.
Posted on Mar 09, 2009
Zyxel
OK here's the user guide. Page 33.
The problem is going to be if your wireless source for the AP's connection will allow an access point to attach to it.
You also have to remember that the AP is considered an attached device by the main router. That means no NAT, no DHCP, no nothing from the AP but a relay of the main router. It has to be on the same IP address level. If you follow the instructions to the letter it should work.
Mar 27, 2014 | Zyxel WAP3205v2 Wireless N300 Access Point
AP loses IP
What exactly do you mean by AP loses IP?
Are you saying the AP access point is no more able to get IP from DHCP server?
or the AP is no more able to provide IP to the connecting users?
Mar 12, 2011 | Cisco AIR-AP1121G-A-K9 802.11g/b Wireless...
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
Code ap
it means add toner (add powder (ap))
Feb 21, 2009 | Toshiba e-Studio120 Copier
The screen says AP -what does that mean
AP means that the copier is going thru a major toner cycle.
Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough.
The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken.
Sometimes the AP message will go away but make sure you have plenty of toner.
Feb 09, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
USB cannot connect to wireless network
"Page cannot be displayed" means "no internet connection".
Go to Start > All programs (XP) and look for Linksys. There should be a "manager" or some type of program. Run it, And look for a tool that will change from "AP mode" to "station mode". Once it makes the change, the networks should pop up. Select yours.
GregM23
Oct 14, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
"AP" ???
Do you have paper in the machine?
Sep 07, 2007 | Copystar CS-1510 Copier
Copystar CS-1530 Copier Logo
53 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
