Question about RTO Fuel Pump Carburetor Transmission Tester Gauge Tool
Daewoo racer 1995, petrol gauge
I have a daewoo racer 1995, and the petrol gauge seems to be reading wrongly, that is, it reads half full when it is less than half full, or reads almost empty when it is half full........How is this checked or fixed?
How many km fuel consumption daewoo racer 1995
Posted on Oct 25, 2011
  • 60 Answers
The easiest fix is to change the sending unit
Posted on Oct 22, 2009
Hi, I m driving Daewoo lanos 2000 m0del hatchback, my petrol gauge decided to stop working 2 days ago, what is the problem?
could be anything but if you are mechanically minded and can get to the sender(sometimes an opening/cover) under the back seats and you will find a plug on top of the fuel pump/sender assembly that goes onto the top of the fuel tank - if there are 4 wires - 2 large and 2 small the 2 small are for the sender. unplug it and link the 2 small wires and if its the sender broken your gauge on the dashboard should read full with the ignition on.
Sep 18, 2017 | Daewoo Cars & Trucks
How do I reset petrol light?????
You can't. no reset for this. Logic chip in the IP is bad if the gauge reads half full. If it doesn't read, replace the sending unit in the tank.
Aug 09, 2015 | Cars & Trucks
Renault laguna computer says warning fuel level low i have put petrol in it still says the same the petrol lights on and the gauge is showing quarter full
Hi Singo the light and gauge are seperate systems that's why they are reading wrong. It's most likely the sensor in the tank of worst case an ECU fault. You will need someone to look at it for you because Renault electrical systems are very temperament and a wrong move could cause other more serious problems. Regards Jim...
May 03, 2015 | 2005 Renault Laguna 3.0
Truck died, will crank but wont start. gas gauge reads empty but its half full
How do you know it is still half full? Sure nobody stole your fuel? or never had a leak. Before saying the gauge is off, try to put in a few gallon, and see it the gauge does a reading. Then try to start again. I learned to trust my measurement tools, unless I could prove they were wrong.
Dec 24, 2014 | 1998 Dodge Ram 1500 4WD
2004 PETROL X TRAIL READS EMPTY ON FULE GUAGE WHEN FULL AND WONT AXCELLERATE
Something is wrong fuel gauge you should have them fixed by a technician to be restored in good running condition
Oct 23, 2012 | Nissan XTrail Cars & Trucks
I have a xingyue xy260t-4 with 2000 miles on it. I am having a couple problems. The first is the fuel gauge reads empty most of the time. Sometimes it will go to half. Any idea what might be wrong? Next is...
My scooter dose the same with the gas gauge it seem to be the reading gauge in the tank if you fill it up and ride it for about 40 miles you will see the gauge go up to full as the gas starts to go down.
Jul 17, 2011 | 2011 Xingyue Xy260T4
Hullo, I drive a 5 door 1.3ltr manual Ford Festiva. When the petrol tank is full the petrol reads full. When the petrol gauge reads around half full the petol gauge falls to zero. The petrol gauge will...
Your problem is the fuel gauge sending unit. It needs to be replaced. Another benefit of owning the durable festiva is the access panel under the back seat. You don't have to drop the tank to fix this problem.
Feb 12, 2011 | Ford Festiva Cars & Trucks
Faulty petrol gauge
I had same problem with petrol gauge bouncing around all over the place, full tank, half a tank and nearly empty in the space of 10 miles.
I knew that if I filled the tank I would get approx 200 miles for half a tank so I did that for a while and just kept topping up. Audi testing it and the fuel sensors in the tank had to be replaced. I'm afraid its the only permanent solution!
Jun 26, 2008 | 2000 Audi A6
RTO Fuel Pump Carburetor Transmission Tester Gauge Tool Logo
531 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
