Question about JVC 580136 Camcorder
I am recieving error E04 "safeguard mode"
The camcorder is in safeguard mode and even when I remove the battery the camcorder remains in safeguard mode. How can I get the camcorder out of safeguard mode so I can use it again?
  • Anonymous Mar 22, 2009
    Exactly the same error message and I can't get the tape out or do anything, I did what the book said about taking out the battery but that does'nt work either.
  • jenjacbeuty May 06, 2009
    i was trying to playback using my tv screen, but the message keep saying in safeguard mode all the time, i just want to see my wedding video!
  • 2,335 Answers
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Posted on Sep 19, 2009
eagle338
  • 4889 Answers
SOURCE: E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Posted on Oct 18, 2007
SOURCE: JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Posted on Aug 20, 2010
kala
  • 156 Answers
SOURCE: E04 Safeguard mode due to Dirt head
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Posted on Jan 08, 2008
  • 5 Answers
SOURCE: 2 PROBLEMS WITH MY CAMCORDER
Some video cameras (Sony for example) have a tiny reset button that can be pushed with a tooth pick, and this does a factory reset and usually solves most lock up problems. The button is in an extremely small hole, usually in the side of the camera somewhere, and is marked reset. See if your JVC has one, and if so then try it.
Posted on Sep 24, 2008
SOURCE: jvc gr-dvx9 E04
The mechanism is out of sync, put a tape in and hold it, it wont go in but will try to open don't let it, remove the battery and reattach, let the tape eject, rinse and repeat 3 or 4 times and it will finally accept the tape.
Posted on Jun 12, 2009
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Safeguard mode
Eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC GR-D73AG Mini DV Digital Camcorder
Safeguard Mode
What error message appears,it should say E0..
May 27, 2008 | JVC GR-D20EK Camcorder
JVC GR-DVX90
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
SAFEGUARD MODE
The most common problem is that the belt for the center pulley comes off. The best fix is to replace the center pully because it is out of tolerance allowing the belt to jump off. Do you have an E03 error code on the screen? This is not a simple repair. The sequence involves a total disassembly, removal of the main board, removal of the mechanism, removal of the mechanism board and cassette-up basket, replacing the center pulley, reinstalling the belt and entire reassembly in reverse order. If you haven't done it before, even as a pro, you're in for a treat...Good luck, magic seadog
May 24, 2007 | JVC GR-AXM225 Camcorder
JVC 580136 Camcorder Logo
1,236 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
