Question about GE WJSR2070B Top Load Washer
Will fill and drain wont agitate or spin
Washer stopped spinning during final spin cycle. next wash try would fill but not agitate. we got it to drain but not spin.
  • billybob177 Mar 12, 2009
    turned out to be the little plastic piece thatfits over the end of the door switch. Replaced this piece with heat shrink as the replacement part was over thirty dollars
  • clownsparkle Apr 16, 2009
    My washing machine is filling with water and just continures to fill. It will not agitate or anything, and as it is filling it is draining the water as well. Sometimes I can sit there with it and play with it and get it to agitate, but this is very rare. What can I do?
  • GE Master
  • 3,361 Answers
Replace the lid switch.
Posted on Mar 11, 2009
  • steve
    steve Mar 12, 2009
    That will do it.
    Glad it is fixed.
3 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
ok. enough humor.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE WJSR2070B Top Load Washer Logo
700 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
