Question about Sony VAIO VGN-S460 Notebook
MY battry not charging But computer is working ok with AC power .... i can plug and unplug battery but no improvements .... what coulsd be wrong ...is beatry completly dead or some other problem ..? SONY VGN S 460
  • supaloonfoo May 24, 2009
    I have the same problem. I reformatted my laptop and updated the drivers but that didnt help. I cant figure out why my battery wont charge...Its at 0% charged but only turns on with ac power connected to it.
    Sergeant:
    Champion:
  • 224 Answers
It would seem the battery is dead, however, before buying a new one, check to see if it is charging as it could be a motheboard problem.
Posted on Mar 09, 2009
My battery do not keep any charge, but its condition was diagnosticated as "excellent" with specialized programs. The laptop works only with an automatic multi adaptor (Woxter brand). The system reports...
"plugged in, not charging" could a symptom of incompatibility between the charger and the battery.
If this is the case, once you unplug your ASUS ac adapter, the laptop goes off.
Anyway, it's still Ok to use the charger but you need to plug it in all the time.
Here is a little trick that I found that works.
1. Power up the Notebook with the battery installed,if you can.
2. Turn the computer completely off and remove the battery.
3. Power up the Notebook with AC power only (no battery installed).
4. Turn the computer completely off and re-install the battery.
5. Power up the Notebook.
6. The message no longer appears (at least for me it has disappeared).
Aug 12, 2013 | ASUS Eee PC T101MT-EU27-BK Convertible...
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Battry di pasang lampu carger langsung nyala dan laptop tidak bisa hidup
google translated
battry in pairs directly carger light turns on and the laptop can not live
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 13, 2012 | HEWLETT-PACKARD Probook 4430S 14 I52410M
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
Dell latitude l400 mother board power problem
SOLUTION  # 2:
The  adapter can be plugged into the DELL the wrong way and it won't charge then. I've done this myself so check to see if the adapter plug that goes into the laptop has a grey battery icon on it. The icon goes on top when you plug it in. For different laptops the symbol may be different than what I mentioned.
Aug 18, 2009 | Dell Latitude L400 CMOS Battery (7.2V,...
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
When ac is plugged in the power light blink & notebook unresponsive
Sounds like your ac adapter (brick) is bad and not supplying correct voltage/amperage.
Apr 03, 2008 | Toshiba Satellite 2805-S603 Notebook
Battery maintenance
you should charge fully then remove power once it is charged.
use it with battery till battery is discharged.
leaving it plugged in all the time will kill the battery.
thanks for rating.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Sony VAIO VGN-S460 Notebook Logo
142 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
