Question about Maytag Atlantis MAV7000
I have a Maytag Atlantis MAV7200 and there seems to a lot of lint at the end of each cycle. I've had it for 3 years now and for the first 6 months it was fine, but now there is just too much lint. I was wondering does this unit have an internal filter and if so, is there anyway to clean/replace it.
    Genius:
  • 1,198 Answers
Http://www.pcappliancerepair.com/model-display.php I don't see any filters at this site for your machine. You could take the pump apart to check it for obstructions. See if you can push the inner drum aside so you can check for anything in the bottom of the outer drum that is not getting pumped out.
Posted on May 13, 2009
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Re Your solution for my washer
its the spin brake making noise at the end of spin. once it gets humid out it will start all over again. its very comm. with this unit.
Apr 08, 2008 | Washing Machines
Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Apr 06, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Lint marks left on clothing
hello are you washing new items new items tend to create more lint within the first few washes check all pockets to see if there is anything left in them there maybe to much wash action for the size and type of load try selecting a less aggressive wash cycle
Mar 10, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
