Question about Car Audio & Video
The CD Player on my 2000 Lincoln Continental does not load. How do I remove the case around the CD Player?
  • 19,396 Answers
There are two small holes on each side of the face plate, you need to use a tool or two thin screwdrivers to remove the stereo.
Posted on Mar 09, 2009
  • Ginko
    Ginko Mar 09, 2009
    To remove the case you should have two small holes to access the two screws inside, if you cannot see the holes then you need to remove a plastic cover around the stereo to remove the screws that lock the stereo on the dash.
  • Ginko
    Ginko Mar 09, 2009
    Look at this example on a Ford, if it has the holes it works in the same way.
    It can be done with screwdrivers , but better getting help from a friend. Even better if you buy the tools.
    If you do not have the holes then you have screws.
    Brigadier General:
  • 5,158 Answers
Have you tried resetting it by unhooking the battery for ten minutes... make sure you have the code for it if it's required
How to change CD player fuse for Lincoln continental
Check the fuse box of the car some have a fuse at the back of the CD player but you have to slide it out to get access to it.
Oct 12, 2014 | 2002 Lincoln Continental
How dificult is it to change 2000 lincoln continental water pump
I would recommend a good independent garage. call 3 on phone and get best price (get labor hours) should be around 200.00 labor
get your own part from auto zone that will save you about 100.00
Good luck
Jul 10, 2014 | 2000 Lincoln Continental
How do you replace the fan belt tensioner on a 2000 lincoln continental
I`m pretty sure your belt tensioner pully is just held on with a couple bolts.Remove your serpentine belt,your main belt.look at the pulley see where the bolts are that hold it on and remove them.They are spring loaded so when u take it off make sure you have the new one to put on because once you remove it ,it is no good and have to put the new one on.
Apr 02, 2014 | 2000 Lincoln Continental
2000 lincoln continental horn and steering wheel controls stopped working
there is a part known as a "clock-spring" that is located behind the steeringwheel, sounds like its broken, probably a $60-$80 part and around 0.7-1.1 hrs installation
Nov 12, 2011 | 2000 Lincoln Continental
Cd play on my 2000 lincoln Cont says empty cartridge, but mag is full
remove and reinstall the mag, it may just be wore out, after all it is almost 12 years old....
Sep 18, 2011 | 2000 Lincoln Continental
How do I change the fuel regulator on a 2000 lincoln continental
the fuel rail will have to be loosened and pulled up enough to remove the regulator, would suggest a knowledgable repair facility or trusted individual
Sep 11, 2011 | 2000 Lincoln Continental
Where is the location of the air ride compressor on a 2000 lincoln continental?
When looking at the engine of your 2000 Lincoln Continental you will notice a coner brace on the left front corner. Directly under the brace you see the air ride comnpressor. you will have to remove the corner brace to gain access to the compressor. Once you do so it is just a matter of a few hard to get to nuts to remove. The compressor has rubber tubes coming from it that supply the air to the air bladders on your suspension. Don't forget the disconnect the battery prior to disconnecting the wiring clips in order to avoid causing electrical damage.
May 01, 2010 | 2000 Lincoln Continental
Lincoln Town Car 1999 driver side window switch
The plastic piece around the switches comes off and the entire cartridge comes out. It just snaps into the armrest. My 98 continental having similar issues. All other switches work, drivers window just quit. Tried a new cartridge did not fix problem.....still working on it.
Apr 06, 2009 | 2000 Lincoln Town Car
2000 LINCOLN CONTINENTAL
I have the same car and don't get bent at this answer .... but if you bought it used and don't know the full extent of the car check the computer and change the steering to low or normal effort ... High effort is harder than my z28 used to be ... and going around entrance/exit ramps you really have to put some effort into it ...
Oct 08, 2008 | 2000 Lincoln Continental
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
