Question about Gateway MX6030 Notebook
Gateway MX6030 will not charge or power up. - Gateway MX6030 Notebook
    Scholar:
  • 45 Answers
It sounds like this could be one of two things:
1.) The a/c power adapter (power cable) is bad and no longer charges your laptop.  You can check to see if the light on the black box that connects the cable to the wall is illuminated, if so...it probably is not the cable.  If it is not illuminated, you can try plugging it into another outlet to see if it comes on.   2.) This could also be a case of a bad battery.  In which case, you might need to look into ordering a replacement.
Both the a/c power adapter and the battery replacement can be found online (ebay, etc), but you should try to pinpoint if it is the cable or the battery before ordering parts.  Cables are cheaper than batteries!
Hope this helped.
Posted on Mar 09, 2009
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Gateway MX6030 bios/boot password reset
How long did you leave the battery out?
To discharge the BIOS you need to short out the battery contacts, or disconnect the battery for 1/2+ hours.
If this does not work the it is near impossible to remove because the password would be stored on an EEPROM chip.
Check with Gateway, they might suggest a motherboard replacement just like IBM.
Posted on Jan 19, 2009
kimbessent
  • 26 Answers
SOURCE: No sound in Gateway mx6030 MA2 Laptop
Make sure the audio cable is plugged into the MB properly.
Posted on Apr 16, 2009
  • 109 Answers
SOURCE: my gateway mx6030 has no multimedia audio
You can download and reinstall the WindowsXP audio driver for your Gateway MX6030 to restore it's options and functionality.
You can access the driver for this system at:
http://support.gateway.com/support/drivers/getFile.asp?id=20463&dscr=Gateway%20Conexant%20Audio%20Driver%20Version:%206.14.10.0565&uid=25562221
Posted on Dec 31, 2009
ghost2233
  • 3606 Answers
SOURCE: Gateway Mx6030 will not charge,
Try to upgrade the chipset driver from here:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=3133
Try also to upgrade them all.
It will do no harm.
Try also to check for bad connections on the battery.
Remember to select the windows you are running.
Good luck.
Posted on Mar 09, 2011
My mx6030 gateway laptop is too dark. i'll try to change the brightness by pressing Fn+ up arrow key but it doesn't work.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 10, 2011 | Gateway MX6030 LAPTOP LCD SCREEN 15.4"...
Gateway Mx6030 will not charge, battey good, power supply good, bounce on sceen betweeen ac and battery when plugged in. as connection not loose. anything that can be done?
It will do no harm.
Good luck.
Mar 09, 2011 | Gateway MX6030 Notebook
My gateway mx6030 has no multimedia audio
Dec 05, 2009 | Gateway MX6030 Notebook
I'm having a power issue with my Gateway Laptop, model number MX6030. Since I've been having issues I have purchased a backup battery, a replacement AC adapter, and had the contact prong to the motherboard...
You have done all you can with what can be accomplished at a local level in fixing the power issues, but obviously it goes beyond the power jack and charger. This may very well involve the power circuitry on the motherboard itself and how the system uses the power from the charger. If you want to look at it from a dollars stand point, it would be cheaper to change out the motherboard than to try and hunt down this problem that may only be able to be fixed by specialized equipment that can de-solder and solder the miniscule pins of the motherboard circuitry. Just to be sure, have someone measure the voltage output of the charger at the tip and make sure it is within the specs of that laptop. Match the output voltage marked on the back of the charger with what you get on a DC voltage meter.
Sep 16, 2009 | Gateway MX6030 Notebook
Screen will not light up.
do you know if you are getting the correct voltages from the power board.
badcapsforum.com is a good place for these types of questions.
Jun 13, 2009 | Gateway MX6030 Notebook
Apr 15, 2009 | Gateway MX6030 Notebook
Gateway mx6030 - need mass storage driver
If you know the brand of your sound driver,go to there web sight ......it should be there.Do you have the book?
Feb 15, 2009 | Gateway MX6030 Notebook
Jan 19, 2009 | Gateway MX6030 Notebook
Computer wont let me do a recovery dvd on my gateway laptop mx6030
try another more experienced repair shop, consider the age of the pc and if worth contacting gateway direct, they are good via email or chat.,
Nov 29, 2007 | Gateway MX6030 Notebook
Computers & Internet Logo
237 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
