Question about Panasonic KX-TA824PK Phone
How do I reprogram a phine to not become an auto outside line? Every time the phone is picked up it connects to an outside line and I can not transfer inside them system.
  • Panasonic Master
  • 2,460 Answers
From the phone, do not pick up the handset, press PROG 11 STORE PROG
It changes line preference outgoing to NONE.
Carl
Posted on Mar 09, 2009
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
I have Panasonic kx-T7453 and one of the Outside lines was already connected to a station and while programming a One-Touch dialing ended causing the outside line to be disconnected to this station. How do...
In a TD system, the lines have 2 digit number 01-12 normally, up to 55 actually. So, if line 1 is missing, press PROGRAM dial 99 press the unprogrammed button and dial 0 01 STORE
Press PROGRAM or pick up the handset and drop it back down to exit programming.
Carl
Apr 21, 2011 | Panasonic KX-T7453 Corded Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
I have the westell 7500. I have DSL with Verizon. The connection keeps dropping since day 1. which was about 5 weeks ago. The tech has been out about 6 times , replacing lines outside . rewired my house....
if you given parallel connection to phone means u have to use one filter for phone and dsl . in that filter 3 plagin will there 1-line in,2-phone,3-dsl or mdem. give connection to 1-direct wire comming for outside, 3- dsl modem, use 2- give parallel connection. if u not done this means when u pick the phone connection will get dropped. still go to this page http://www.rajasthan.bsnl.co.in/main/trsh.htm or call me 9740575949 moz-screenshot.png
Feb 25, 2010 | Westell Wirespeed VersaLink...
Keep getting message "incomplete data" when a call comes thru
You've probably enabled caller id CLI on your phone but don't have it enabled as a feature on your phone line.
Hope that helps
Jan 14, 2010 | RCA ViSYS 2-Line Speakerphone
The fax will not answer even though I have it set to answer after 2 rings. It is on a dedicated line. Help!
There is a check box that must be checked in order to enable automatic answering.
Also, you have to have the phone line plugged into the Officejet machine
Oct 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY TELEPHONE BUT SEEM TO HAVE LOST THE OUTSIDE LINE TO CALL ANYBODY, ALL I GET IS co NOT ASSIGNED, CAN ANYBODY HELP ME THROUGH IT?
If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
Carl
Apr 22, 2009 | Panasonic KX-T7730 Corded Phone
Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Dec 17, 2008 | Nortel T7316E 2-Line Corded Phone
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Vodavi Triad 1
You will have to reprogram the "line selection" from a defined line to first line available. This will require reading your instuction booklet, line selction sould be listed in the index. I'm sorry but I don't have the specific programming information you will need to reset the phone. Thank You. Jerry
Feb 08, 2008 | Lands Phones
Panasonic KX-TA824PK Phone Logo
118 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
