Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 6 Bushel 2 - Bin Hard Bagger for 42" Deck
Parts needed and how to attach the Craftsman 6 Bushel 2 - Bin Hard Bagger for 42'' Deck to the riding lawnmower. If possible can a Diagram be given?
5 Suggested Answers
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 376 Answers
SOURCE: I need a diagram showing how the throtel cable
The throttle cable doesn't attach to the carburetor. The 'z' bend in the end of the cable sticks in the white plastic slide at the bottom of the control plate on the left rear side of the engine and the cable is held in place by a clamp behind it.
Posted on Jun 10, 2009
huffman49
  • 235 Answers
SOURCE: where is the choke located on a craftsman riding
the should be a cable near the throttle on the dash by the steering wheel. if not look at the carb there should be a sliding choke on the front of the carb..good luck
Posted on Apr 14, 2010
SOURCE: i need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Posted on Jul 30, 2010
heatman101
  • 43501 Answers
SOURCE: my craftsman riding lawnmower 42"
The first thing to check is the wheels on the back corners of the deck....amke sure that they are set at the same height and that the bearings are not out of the wheel, which would allow the deck to sink lower on one side.
If all of that checks out then you have problems under the deck....
The bearings that hold the blades can wear allowing one of the blades to drop, or one of the blades could be bent which could cause it to cut lower...to fix that bearings will have to be replaced or the blades will have to be replaced if bent.....
These would be the causes for your mower to cut unevenly...
heatman101
Posted on Apr 09, 2011
L110 bagger installation
I can't help you on the bagger hole location. But you will need quality hi-lift blades. "Gator-Blades" are some of the best. At www.mowpart.com or Amazon.com
May 16, 2014 | John Deere 6.5-Bushel Bagger for Twin...
Looking for replacement soft bag for craftsman 9 bushel 3bin soft bagger
Go to E-bay. Type in what your saying here. About $100 CHEAPER.
Sep 05, 2013 | Craftsman Garden
Need help on installing a 2 bin hard bagger on a craftsman lt1000
call sears, and ask them to get you the manual.
Nov 20, 2011 | Garden
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need your assistance please
http://www.superxpower.com/pages/parts/viewbybrand/default.aspx
try this link, they don't deal specifically with craftsman parts, though they do have aftermarket suitable substitutes for craftsmen. This website has excellent illustrated parts breakdowns for numerous other riding lawnmowers though and I'll bet that something like MTD or White Outdoor is exactly the same as your mower. I have a White outdoor 42 inch riding mower and have changed numerous parts using these illustrations. Good luck
Apr 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
756 people viewed this question
Top Craftsman Garden Experts
Dwain Pippen
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
