Question about The Times ROYAL TC100 TimeMaster Time Clock
Incorrect day i was able to set the new time, but I can't seem to be able to set the correct day we are on.
  • 3 Answers
Find the 3 buttons on thefront under the cover. Hold down Mode untill hour blicks. Set the hour, minute, and seconds by pushing Setting. Then push select after each to set. Then the starting with the year you should be able to set the date using the same method after. Year, month, day
Posted on May 10, 2009
  • freakchik4 May 10, 2009
    If this doesn't work you can go to Mode P1 and select on of the following and just hand print the starting and finishing dates of pay period... 3 will post time, week day, 6 will post time only
I have a 1986 isuzu pickup it is a 2.3L 4cyl 5 speed 4x4, whenever it is given higher gas it tends to knock quite loudly, timing belt is fine and all fluids seem to be up where they should be.
the knock is most likely detonation or spontaneous combustion
it comes from incorrect air / fuel ratio, incorrect ignition timing,
incorrect rpm for the throttle setting
It is detrimental to the engine as the increased combustion temperatures will melt piston tops if allowed to persist unfixed
start by running the fault codes to find the problem area
( most likely a heated oxygen sensor (HO2S) in the exhaust manifold not reporting correctly to the ECM which controls the injector settings
Sep 28, 2016 | 1986 Isuzu Pickup
Sony experia m my phone doesn't want to update my watsap, just says my date an my time are incorrect whAt must I do?
it means that your date and time setting are not correct. But sometime that error appeared even when your date and time setting are correct. If so, just ignore it for a day and it will be okay, but make sure you have the exact correct date and time first before ignoring it. FYI: Just using auto date and time doesn't mean your setting is correct the auto can be wrong sometimes
Jul 15, 2014 | Cell Phones
Time and date are not set correctly
When the Date and Time is set in the BIOS setup or in Windows and when you boot up next time and the date and time are incorrect then the problem is a flat BIOS battery. A flat BIOS battery cannot keep the Data and Time stored in the BIOS. Replace the BIOS battery and set the Date and Time etc and the problem will be fixed.
Apr 04, 2012 | Toshiba Tecra S3 Notebook
Citizen Skyhawk - analogical time displaying incorrectly
Go to the "" website
Select "technical support"
You will see "setting instructions", where you must enter details of your watch.
Since they have a "setting "selection, your problem seems to be a common one!
Dec 27, 2009 | Citizen Skyhawk A-T Watch for Men
I entered product key from base of my laptop and it stated to retry as it was incorrect. this number was correct when I rechecked it 3 times. I had the mother board replaced as this laptop is only 8 months...
good day, well it seems the original software that is being installed has been change since you you have change your motherboard. The new installation is different from the old one i'm sure, so check with the store who re-installed your software/OS...
Aug 18, 2009 | Aspire Acer 7520-5071 Notebook
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Sep 27, 2008 | Emerson Audio Players & Recorders
Change clock display??
Press Feature.
Dial _9#.
Enter hour and minute via dialpad.
Press Recall to change AM/PM setting.
Press Hold to change to calendar setting.
OR Press Feature to exit this feature.
Press Recall to select day of week.
Dial # to move the cursor to day of month field.
Enter day of month via dialpad.
Press Recall to select month.
Dial # to move the cursor to year field.
Enter last two digits of year via dialpad.
Press Feature.
This must be done from a phone with attendant features set. Typically ports 1 and 2. More than likely x10, x100, x1000 or something like this.
Mar 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
You must set the clock once so that the
system announces the correct day and time
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
call information is received.
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
the correct day is announced.
3 Press and release C. The current
hour setting is announced.
4 To change the hour setting, press and
release ror auntil
the correct hour is announced.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
the correct year is announced.
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
The Times ROYAL TC100 TimeMaster Time Clock Logo
433 people viewed this question
Top The Times Office Equipment & Supplies Experts
Are you a The Times Office Equipment and Supply Expert? Answer questions, earn points and help others
