Question about Samsung SF-565 Laser Fax
Toner empty Hello  I have a samsung SF-565PI use cartridge #SCX-4216D3/SEEI put a new one in and it keeps saying,"Toner out".I cleaned the little silver metal pins with alcohol and there is still a problem. What can I do. Help
My guess is that this cartridge is remanufactured??
It requires a chip or fuse be replaced, in order to reset the machine when you replace it, and maybe this chip is defective or was overlooked.
If it's an original Samsung, then this is not likely the problem.
Posted on Mar 12, 2009
SAMSUNG CLX-3175 how to enter the tech menu
Press: Menu # 1 9 3 4 OK Menu
Tech Mode / Tech Menu should now be shown on screen
Mar 19, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung SCX-3200 FUSER UNIT FAILURE #U1-2113
fuser unit failure #u1-2113, how to solve this problem?
Jan 15, 2012 | Samsung Office Equipment & Supplies
Put in second toner and machine is still saying toner empty
If you are using refilled cartridges those errors are common, Samsung has an eeprom on the cartridge keeping track of usage and you need a new chip from the refillers. If you are using OEM cartridges you need to clean the contacts inside the machine that the cartridge connects to and wipe the contacts on the cartridge before installing, Otherwise a shop repair for the CRUM circuits.
Sep 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
It was saying toner empty so i put in a new one and its still saying that i have no toner . i am not recieveing faxes for work. what should i do
Take a q-tip with some rubbing alcohol on it, remove the cartridge and clean the little metal strip on it and then take another clean q-tip with a little alcohol and clean the place where it makes contact
with the holder, use a flashlight so you can see everything, and make sure these places are clean.
Please post back if any more questions,everyone is more than happy to help you.
Mar 25, 2009 | Samsung SCX 4521F All-In-One Laser Printer
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF-565 Laser Fax Logo
214 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
