Question about RIM BlackBerry Curve 8310 Smartphone
Calendar Synchronization My calendar will not sync from my desktop (Outlook) to my Blackberry Curve (8310). I connect the cable and begin sychronization, but it always stops at the same record (number xxxx of yyyy). How can I get past this, or how can I identify the problem record to delete it and move on? Thanks. Lu Dorfman ldorfman@bethyeshurun.org
  • 41 Answers
You might want to download updated blackberry software. Your information will be saved.
Posted on Mar 13, 2009
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Synchronization problems Desktop Manager and Outlook 2007
First, download and install the latest version of BlackBerry Desktop Manager software (5.0.1) from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Nov 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
How to import calendar and contacts from outlook to BB
Step 1 Install Blackberry Desktop Manager Manager from
http://na.blackberry.com/eng/services/desktop/
Step2
Connect blackberry to your PC using a USB cable and let blackberry device driver install. When device driver install is complete, it will alert "hardware installed successfully" in your windows task tray.
Step3
Run Blackberry Desktop software and choose SYNCHRONIZE option.
Step4
Now choose CONFIGURE and you may select CONTACTS, CALENDAR, NOTES, and TASKS databases by clicking check boxes next to each. After you select each item, it will ask which application you would like to sync it with, you will choose OUTLOOK for all.
Step5
Now click OK out of all windows until you are at the main blackberry desktop manager screen. click SYNCHRONIZE. Make sure that the SYCHRONIZE ORGANIZER DATA check box is checked. Now click SYNCHRONIZE NOW to begin synchronization.
Hope it helped.
Nov 21, 2009 | Cell Phones
How to set up sync between blackberry 8310 with outlook 2007 contacts
you have to open your blackberry desktop manager software. goto synchronize, and then configure synchronize and then tell the desktop manager to sync with outlook for you contacts calendar and so forth. so from then on when you plug your bb into your pc and strat up desktop manager, when you choose to sync it will sync your bb with outlook.
Oct 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
How to transfer contacts to blackberry from pc
you should go to blackberry's website and download the latest version of the blackberry desktop manager. download it and then goto synchronize and then configure sync. tell desktop manager to sync with outlook for contacts and calendar and then select sync and it will synchronize your pc and your bb.
if you use gmail, you can goto m.google.com/sync on your bb and then download google sync. goto your outlook and export your contacts as a .csv file and then import them into your gmail accont. when you login to the google sync app on your bb, it will then wirelessly sync your contacts on your bb with your gmail account.
Oct 01, 2009 | RIM BlackBerry Curve 8310 Smartphone
MY PHONE WILL SYNC ALL BUT MY CALENDAR
Open Calendar.
Press the Menü Button
Select Options
set Wireless Synchronization to „yes“ Hit the Back button and select save – all calendar entries should be synchronized from now on
Jul 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Caalendar on my desk top for my blackberry curve 8300
the blackberry will be using the Outlook calendar to update its information. its quite easy to use. What's happening is that the items calendared on the BB are syncing with the "private" calendar under the username (Outlook Today - Username - Calendar), and not the "public" calendar (All Public Folders - John Doe). No items are marked as "private" on the BB.
Install the Blackberry Desktop manager software and after its done go to the Syncronize Button. Once inside look to the left for configuration synchronization click this button it need you to be online to do this as well. inside it will list the many programs that can be used to sync your blackberry make sure you have already setup your outlook so that it can pick up the new settings your creating. once your all done look for the top upermost button on left of BDM ( blackberry desktop manager) and click syncronize to sync your blackberry. now once it is done your BB only needs to be plugged in and it will autosync itself. look in your outlook for new entrys and popup
Apr 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
My phone will not sync with my Outlook calendar.
As a past Blackberry user i simply gave up on this. I would suggest using an outlook email account as Microsoft unlike gmail provides Active Sync for all free accounts these days. Give it a try and see if you can get the calendar to to sync. Also, if you are using outlook desktop software 2013 then you get a full feature active sync exchange style email.
Oct 23, 2017 | RIM BlackBerry Curve 8310 Smartphone
How to manage BlackBerry Curve 8330 calendar from home PC desktop
The blackberrys link to outlook and not their own calendar/contact manager. If you have outlook at home, you should be able to use the desktop manager software to sync with that.
Feb 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve & Outlook 2007
To get rid of the unknown error, you will need to uninstall the Blackberry Desktop software. When you do this, make sure that you have the uninstaller delete the user settings, too. Then reinstall Desktop Manager 4.3. See if that helps with the syncing, too. This solution solved the error problem for me, so I hope it will work for you.
If this does not solve the syncing problem, then post back here again and we'll look for another solution. Sometimes a .pst file repair will help.
Jun 04, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
284 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
