How to disassemble the mailmate spl-727MM. I think there are 2 screws from the bottom under the rubber pads and I think you need a long screw driver but what kind? Phillips or regular? No. 1 or No. 2?
  • jerejuana200 May 05, 2009
    The mailmate spl-727MM will not turn on and need information on how to disassemble.
1. Remove the two rubber pads (only two out of four pads with Phillips screw, you should be able to see which two).
2. Use a long Phillips screw driver to remove the two screws
3. You may still not able to remove the the housing because there are double side tapes sticking the front part of the housing to the shredder's base, use a ruler (steel ruler) to detach the tapes
4. You should be able to pull out the housing (the machine should be up-side-down) and you should be able to do what you wanted to fix.
Enjoy.
Posted on Aug 17, 2009
  • johnd393 Jan 17, 2011
    For my spl-727mm there are 6 screws accessible through holes that are visible with it upside down and the tray removed, I drilled 6 holes on the bottom so a long phillips screwdriver would reach the screws. My mistake was letting some plastic, from the drilling, fall in the screw holes. The head of one screw got clogged so the screwdriver couldn't get any byte on the screw. The other 5 came out easy. I used a #2 phillips but had to select one that was thinner so it would fit in the holes. With the screws out it came apart easy, except I had to bust some plastic where that one screw went. The fuse was blown. I installed a 270-364 fuse holder and 270-1011 fuse from radio shack. It's working, but it does not auto power shut off. We just turn it off.
  • 3 Answers
Answer above is right. Just elaborating ... (1) Disconnect power. (2) Pull out clippings bin. (3) Turn shredder over and remove rubber pads that cover screws. Only 1 or 2 pads actually have screws: looking inside where the clippings bin was, look for the plastic tubes running from top to bottom in the four corners, only two of them go all the way. You need a Philips #2 screwdriver with narrow, 9" shaft. Undo the screws. They're short, less than 1/2". (4) Turn the shredder upside up again, front facing you. Hold your hands together, palms up. Put your fingers into the bin zone (short of the blades of course) and pull the ceiling upwards, while your thumbs press the walls of the shredder inwards. In other words you're holding the outer casing down with your thumbs, while trying to push the power unit up. Rock it a few times. Look at the front panel where it says Staples and Mailmate. It will separate a few millimeters from the rounded top section above it. There's a strip of double-sticky Scotch tape right in there, you can't see it. Take a steel ruler and slide it into the gap and the tape disengages. Or slide a screwdriver in vertically about an inch, and twist it. The tape gives and everything loosens up. With the power unit off the shell, another 6 Philips screws and you can open the power unit.
If the unit is not coming on, chances are the blue-lit button has failed. There are three other power controls: the black on/off rocker switch on the back, the bin-in sensor and the paper sensor. Use a non-contact tester to trace the path of power. The blue-lit button has 4 contacts but is just a SPST momentary switch. Tap the wires from there and install your own momentary switch off to the side and the unit may work.
Posted on Dec 20, 2015
How do you remove the bottom of the blender?
A inexpensive set of security bits from Harbor Freight contains compatible screwdriver heads. There are actually 4 tamper resistant screws- two are hidden under the rear rubber anti-skid pads.
Jul 23, 2014 | Margaritaville DM1000 Blender
Have a Staples Model SPL-727MM paper shreader that won't work. Probably jammed, but unable to open it. Found some screw holes in where the tray pulls out, but regilar screwdriver won't fit, too long. Does...
Some home office shredders have the shredding mechanism "permanently" attached with only the bin (tray?) removable. The entire machine has to be inverted to gain access for cleaning. Periodic cleaning is necessary maintenance as shredders of this type are not self-cleaning.
May 17, 2014 | Office Equipment & Supplies
Lionel train desk lamp not working consistantly.
There are 6 rubber foot pads that under each one is a screw. I had the same problem and we found out that there were screws under the rubber foot pads. Once we were done we glued the rubber foot pads back on the lionel lamp. (Lionel Train Desk Lamp)
Apr 21, 2013 | Toys
Staples mailmate SPL 727MM will not power up
Shredder refused to power on. No light... nothing.
1st step: (MAKE SURE THE THING IS UNPLUGGED FROM 120 V FOR FOLLOWING STEPS)
So, i dismantled it according to previous postings and inspected visually everything. Nothing had heated, all solderings were OK on the boards. Did few checks on the interlock drawer switch with an ohmeter: tested OK. I removed the 2 screws holding the little board where the power on switch is mounted. Ohmeter said no action across switch prongs when i push the button. I drowned the button with tape head cleaner and activated the button a hundred times. After it dried, i repeated the operation.
It cured the problem. I Dont think these kind of switches can be found... cheap stuff.
Had some problem finding a 10 inches phillips screwdriver to open the case... Electronic store had one...brand is Xcelite.
....have fun challenging those China made gizmos !
Sep 27, 2011 | Staples SPLXC200D Shredder
How to I disassemble a philips ajl308/37? I removed all the screws but it still will not come apart. The display keeps flickering and eventually it just goes black and won't come back up.
My unit did the same thing. Did you remove the 2 white rubber pads on the top at the back. There are 5 screws total. If so you then have to use a smaal flat screw driver on the sides to get the cover to unlock from the back There is also some double stick tape that holds the 2 halves together so its a little tricky.
May 20, 2010 | Philips AJL308 USB/SD radio alarm clock
Disassembling the speakers - Compaq Jbl Pro (401508-001)
pry the speaker cover slowly using small screw driver on the side,,it has four locks giong thru..its position two at the top and two at the bottom..it is line w/ the volume control and headset..be careful not to break the speaker cover.then remove the four screws inside the hole where the speaker cover is position.remove also the rubber protector beneath the speaker or under the speaker..it has a lock beneath the rubber covering it..push the lock slowly, be careful not to break it.but even if you break it,it will do nothing..now insert finger in the hole and pull the face or pry w/ small screw driver and lift...
Apr 15, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Staples shredder spl 727mm - quit working all of sudden - jammed?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}First, don’t destroy anything on the top of the machine.Eight screws. Two are accessed through the rubber foot pads. Six are accessedfrom the basket compartment. You will need a VERY LONG AND SKINNY Phillipsscrewdriver with a foot-long blade and a very narrow diameter to fit down theaccess holes. I cut my case in two to get at the six screws through the basketcompartment (very messy). It would probably be easier to drill holes throughthe bottom of the case for screw access. You could then use tape to cover the holes.
Our shredder quit running while in use. Staples said itwould probably need a new circuit board. Once I got inside I found a 5 amp fusesoldered to the circuit board. Yes, it was blown. I jumped it and the machineworked. I unsoldered the fuse and soldered in two wires that I ran through ahole I drilled in the top of the machine. I took a 5 amp automotive fuse(bayonet style) and drilled a small hole through each bayonet. I then threadedthe two wires through the two holes on the fuse and wrapped them around,instead of soldering, for easy future replacement. Then I wrapped the fuse withelectric tape for safety and taped the fuse flat to the top of the machine.Voila! A flawed Chinese product is made usable! Dan Phelps delps@charter.net
Feb 09, 2009 | Techko SH1524CP Shredder
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Mailmate by staples shredder won't turn on
I took my mailmate out into the driveway. got in my truck and ran over it two or three times. it doesn't work any better but I feel great.
Oct 25, 2008 | Office Equipment & Supplies
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
May 11, 2008 | Medion MD-40954 Notebook
6,752 people viewed this question
jasbo
jasbo
