Question about Black & Decker T1400BD Versatoast Cool Touch 4-Slice Toaster
VersaToast T1400 My lever would not stay down. It toasts if i hold it in place. Is that the end of it?
    President:
  • 267 Answers
THERES A RECALL ON THIS TOASTER CALL BLACK & DECKER @866-264-9230 FOR A REPLACEMENT TOASTER ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 13, 2009
The levers on my toaster model 3099249 will not stay down and lock in place for toasting. Why?
make sure no forien objects are in the toaster.....if not then the spring metal that holds it down is probably broken off.
Oct 11, 2017 | The Kitchen Appliances - Others
Fix sunbeam 3806 toaster that won't stay down and therefore heat bread.
Just a guess since I have had the same happen to my Proctor Sillex - When you push down the lever, you are actually completing the transformer frame that then magnetically keeps the toast down until it's setting lets the toaster pop up.
In my case, a piece of toast was wedged and I could not get the handle down so that the hardware was in place to magnetically hold. Have you tried to give your toaster a good thorough shaking upside down, unplugged over the garbage can or the sink?
Good luck Eric
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
Lever does not stay down. Does not toast
Hi
This is a common problem after heavy usage. You need to open the toaster and adjust the lock which holds the lever in place. Which is connected with the Thermostat, as the thermostat trips it will pop the lever and the Mechanism connected out.
Aug 01, 2011 | Oster Kitchen Appliances - Others
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Toast wont stay down in toaster it wont lock in place
I'm at the same crossroad. Thry holding down the lever for more than 4-secs. The light will blink once, then it is as though the circuit is over-ridden and a toasting cycle will begin. This might help to eliminate wether you have a mechanical or electrical issue. Mine appears to be electrical. I'm now investigating if it is the timing or relay?
Jul 15, 2009 | DeLonghi CTH4003 4-Slice Toaster
BTA320 bought today. Lever wont stay down to toast.
Since this is brand new, I would suggest return it for a new one.
May 02, 2009 | Kitchen Appliances - Others
Lever on taoster will not stay down
I would just buy a new toaster...they are not that expensive. Check the intruction book first because maybe it's under warranty. Or if you bought it very recently, just take it back to the store. Most places will take it back even without a reciept if you tell them you just bought it and it's already broken.
Nov 22, 2008 | Kitchen Appliances - Others
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Black & Decker T1400BD Versatoast Cool Touch 4-Slice Toaster Logo
223 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
