Question about Sewing Machines
Delta ssewing machine md. no.11871
Needle thread wont connect with bobbin thread
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
  • 25 Answers
SOURCE: machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
Posted on Jun 02, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
My stitch wont stay in the fabric what am i doin wrong
needle thread tension worng
no thread in the bobbin
neeld /hook timing is wrong
May 14, 2017 | Sewing Machines
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
My mother"ssewing machine willnot pick
I saw Nelco on this website http://www.sewusa.com/Sewing_Machine_Manuals/Nelco_Sewing_Machines.htm
purchasing /obtaining a manual is always very helpful when working with a sewing machine.
However, simple stuff to check, is the needle in the right way, with the scarf (groove) to the back?
Is the needle new and the right type of needle for this machine? Sorry, I don't know a lot about Nelco however, most machines use 130/705H system needles, but there is always the exception, especially with something 40+ years old so it pays to check it out.
And lastly timing, the needle needs to be down at the lowest point as the rotary hook comes around to catch the thread. If this isn't happening, then it could be that the timing is out on the machine. It's never happened to me but it can happen. But I'd suggest you try changing needle, check threading path and bobbin firstly.
Good luck.
Apr 10, 2011 | Sewing Machines
I broke a needle and now it wont pick up bobbin tread
Hello
Make sure the needle is facing in the correct direction,stitches don't form, or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail after threading the needle.
make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case.
Also check if the needle is not properly installed in the needle bar,the machine is not threaded properly or the machine needs adjustment or repair..
Feb 12, 2011 | Euro-Pro 416 Mechanical Sewing Machine
I have a delta sewing machine and cannot get it
Some of the older model sewing machines do require that the eye face toward the right. This would be the side of the needle that has the long groove for the thread to follow down the shaft and through the eye.
I cannot find a manual for a Delta sewing machine, so I would try the needle both directions.
Can you open the bobbin area (bottom spool) and watch to see if the needle and bobbin thread are connecting?
Apr 29, 2010 | Singer 7462 Mechanical Sewing Machine
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
Bobbin wont feed
a. needle in backwards
or
b. needle threaded wrong
Apr 24, 2009 | Sewing Machines
Ssewing machine consew model 99 - thread in bobbin too loose I tighten screw as far as it can go - did not help also need to verify how to thread machine - this machine was given to me with the wrong...
Dear Sir / Madam,
You will need to remove the screw and the tension plate as there is a lint build up behind the spring.
If there is no lint then just gently bend the spring so it fits a little tighter on to the bobbin case.
Kindest Regards,
Richard.
Jul 17, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
155 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
