When I insert a cassette into the VCR, it is immediately ejected, no prompts, no hesitation.
  • 19,396 Answers
That is a mechanical error, to fix this you need to take the unit apart.
Posted on Mar 09, 2009
  • Ginko
    Ginko Mar 09, 2009
    If the tape is ejected immediately, that means that probably there is tape rolled inside the VHS drawer, probably because of an old jam.
    You need to access the internal mechanics to fix the problem, this will be much easier on a dvd unit rather than a combo TV.
Sony vcr se720 leaves a loop of tape when ejected?h
I used to own a Sharp vcr that periodically did the same thing and the engineer would replace a rather expensive roller and clutch assembly. I think it was called an idler reel.
When a cassette is inserted the mechanism draws out a loop of tape that must be rewound when eject is pressed. The mechanism is fairly complex and engineers use a special cassette in order to view the operation...
Sep 15, 2017 | Sony Televison & Video
Bought this tv/vcr combo at a garage sale. They said it worked. I have no remote. When I insert a video tape it immediately ejects the tape. Any suggestions?
Cassette tape is not loading properly. You should check its belts. This is purely a mechanical trouble. To access it, you have to take out the deck mechanism out. If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option
Aug 05, 2013 | Panasonic PV-C2061 20 in. TV/VCR Combo
Mitsubishi VCR Model HS-821V Ejects Video Cassette & gives an error code E4
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
Nov 26, 2012 | Televison & Video
VHS cassette accepts and ejects with kir..r...r sound. I have removed the power cord (Power OFF) and cassette was inserted halfway and then plugged the power cord (Power ON). At this time the VCR ejects...
First of I think you have a K-Deck mechanism. If you do a Google search for "Panasonic K-Deck" you should find the free information. If you can't you will need to E-Mail me.
This sounds like a a timing problem, perhaps caused by some damage to the Cassette Holder. The mode switch could be part of the problem too. They are quite tricky to set up to get the timing right, I do know the Cassette has to be inside the machine to set it up. The good news is that parts are easy to get hold of, so if any thing is damaged it can be replaced. Curry's partmaster is a good place for parts.
Oct 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Inserted cassette doesn't play and immediately ejects
Could be a mode switch problem, you could try Servisol video 40 on the switch, or it might need replacement.
Mar 03, 2010 | Panasonic PV-V4022 VHS VCR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Canon UC8Hi ejects cassette when it is inserted
Canon UC8Hi: The cassette is not retained when the door is closed - it is ejected again immediately. IF it is not ejected, the ''EJECT'' light flashes.
Jul 28, 2009 | Canon Video Cameras
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
