Question about LG WM-2277HW Front Load Washer
Water leaking from my front load LG washer
This never use to happen before, it started a few months ago and it doesn't happen all the time. Not sure what is wrong but wast leaks from the bottem of the washer
  • Anonymous May 25, 2009
    My machine leaks from the bottom when not in use!
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    What type of soap are you using and how much? Do you have soft water?
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Posted on May 26, 2009
Mine had the same problem a small amount of water coming from underneath. My washer had a bad hot water inlet valve. The part was about $16.00 part #1268123 the inlet valve is located on the upper back of the washer. you have to take off the top cover of the washer to gain access it's not that difficult about a 30 minute job.
Posted on Jul 01, 2009
If it's not the door gasket check the water control valves. They can continue to leak without the washer being turned on.
Posted on Jun 10, 2009
My LG WM2650HWA front load washing machine is 13 months old. A few weeks ago I noticed water at the end of the cycle in the front of the machine. Upon further inspection I noticed soapy, water at the
It's very common for the sump hose to have a hole in it causing it to leak. The quickest way check is to tip the washer back and examine the sump hose by stretching it, as you stretch the hose you should find your leak. You'll also want to check the door gasket for cuts and the drain pump assembly for leaks. Let me know what you find.
Sep 28, 2014 | LG SteamWasher 3.6 Cu. Ft....
Help ! We have an L G front Load washer model # WM2016CW that leaks soap out the front bottom of the dispenser. It is 2 years old and I have followed all the manufacturers instructions on using HE soaps...
You can remove the dispenser and place it in the dishwasher for easy cleaning.
I have included some notes on your washer and I have a service manual for you HERE
Apr 07, 2011 | LG WM-2277HW Front Load Washer
LG front loading washing machine. SEVERE water leak from front door. Gasket has been checked and is OK. Seems there is quite a bit of 'play' (i.e. slack or free movement) in the front door since if you...
This is a very common problem with the LG front loaders, and some other front loaders for that manner. There was a few recalls on them and some parts that were supposed to fix the issue. Even if the gasket looks ok i would replace it, as they have updated the design of the gaskets to fix issues on models that were having issues leaking. Most of the time its just a bad gasket and you cant really do anything other then replace it. Front load washers are about the worst appliance made today in my opinion, the repair shops around here are always full of broken and leaking front loaders. I have fixed quite a few myself, some work ok after the repair, some fail again in a matter of months, its a real duck shoot on them. The biggest failure rate though is the gaskets! And most of the time they look ok but still leak like a screen door.
May 04, 2017 | LG WM-2077H Front Load Washer
LE error code during wash cycle (washer full of soapy water). Washer does nothing now (no spin etc). Any ideas?
having the same problem - means load is too heavy so take stuff out then try to re-run it. I read some time ago that this eventually happens with front-loaders - they can't handle the weight - I had less than half a load in there and had to take stuff out. Time to have it serviced but still usuable with only a few pieces of cloathing.
Jan 27, 2010 | LG WM-2277HW Front Load Washer
LG Washer leaking water underneath
Some times a water valve can have a leak inside the machine coming out the bottom.
Also make sure the filter in the front lower left corner is tight in the housing.
Tub inside could be damaged from shipping.
Sears should be able to fix you up.
Jan 20, 2010 | LG WM2016C
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Oct 08, 2007 | LG WM1815CS Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,506 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
