Question about Fujitsu Siemens Computers & Internet
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
It has crashed and is giving error message NTDLR is missing.Press Alt+Crtl+del o restart, and if you follow that instruction it happens all over again. Fujitsu Siemens cant sell me a boot disc. This compueter was sold with windows 98, later upgraded. They asked me to look for a windows 2000 installation disk. Is that what I should do? Will that serve as boot disc? What happens if a computer can be booted? Can it be 'killed' and new windows installed
  • Mohini Hersom Mar 10, 2009
    Dear Khushroo, When you say that I must go to "repair windows" I think you are referring to something that is expected to come up, when I insert and windows 2000 professional installation CD. The computer has crashed so unless it starts to boot I cant go to "repair windows" right? Well, I am trying to get hold of a windows 2000 installation CD Rom. HOwever I'd like to know, in case the CD-Rom drive is not working, can it be booted? I have been into Setup-i am able to go to setup-there are no options for USB drive as booting device. Only Floppy drive CD-Rom drive and hard drive are listed as options in Setup for booting. I think if I use the floppy disc for booting-floppies have only 1.44Mb and I need a program less than 1.44 Mb. Can this be done. Is the computer a write-off if I insert a windows installation CD in the DC-Rom Drive and NOTHING HAPPENS?
    Problem Solver:
  • 10 Answers
To fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
c:\exit
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Posted on Mar 09, 2009
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
Hello just want to ask how this problem be solve... BOOTMGR is missing Press Crtl+Alt+Del to Restart. pls help
It is an error message meaning your missing your operating system or your operating system is corrupt.
An easy way to fix it is by reinstalling the OS but be warned you will lose your data on the hard drive.
Nov 05, 2010 | Computers & Internet
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
PREINST6.SWM missing; PREINST9.SWM missing; Error:10-FC06-0002
Means pre-installion is missing. Which means yoou either have to Reinstall a fresh copy of your windows or your can reinstall your windows by just repairing the files. Its always good to make a recovery disk after every install. If you haven't tried it already restart your pc press f8 as the scene pops up and go to Last good configuration.
May 30, 2009 | Toshiba Satellite Pro L300 Notebook
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
BOOTMGR is missing
Just had this problem kept getting
"BOOTMGR is missing
Press ctl+alt+del to restart"
and it just cycles through to the same screen. Called tech support and this is how they solved the issue for me in less than 10 mins
turn computer off completely
Hold the "alt" and "Fn" down and power computer back on
While computer is powering on tap the "F10" key
(you need to hit the F10 key on the black screen with the cursor just before the BOOTMGR error appears)
You should get a screen that says "Windows programs Loading"
And then you have to run a restore to factory defaults (this means the computer will work fine once it finishes up the restore, but everything saved on the computer will be lost)
Hope this helps.
Feb 24, 2008 | Computers & Internet
Fujitsu nightmare
This is because it has not written the system files yet as it has frozen on repair. assuming youv'e set the cd as the first boot device, it sounds like a complete re install is now necassary, but if you get the cd to run you will need to format the drive first then a clean re install.
Jan 16, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
308 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
