Question about Sony PlayStation Portable (PSP) Console
Cannot Use Wireless LAN
I just bought my PSP and for some reason cannot access the internet with my PSP even when I sit right next to my home computer with internet access and have 100% signal strength. When I try to access it, it will search for the IP address and then give me this message: "A conection error has occured. The atempt to obtain the IP address timed out" I checked the Sony PSP manual and everthing is set up correctly according to the troubleshooting section. I am not sure what the problem is. Any help or advise would be greatly appreciated. Thanks, Ben
  • 8 more comments
  • Joshua Lee Feb 17, 2008
    Ok. This is what it said. And by the way my PSP is pluged into my computer.
    WLAN Settings:
    Scan
    Enter Manually
    Automatic
    Use Wireless Hotspot
    I clicked on Scan. Then I clicked on scan and this is what popped up.
    SSID Security Signal Strength
    sbxli WPA-PSK (TKIP) 67%
    I pushed right because it was highlighted and blinking. Then it came up on the screen automaticly:
    SSID
    sbxli
    I pushed right because it was highlighted and blincing. Then this popped up on the screen.
    WLAN Security Setting
    None
    WEP
    WPA-PSK (TKIP)
    WPA-PSK (AES)
    WPA-PSK (TKIP) was highlighted and flashing so I pushed right.
    It went to WPA Key. Do I put in my IP Address for the WPA Key? I did that.
    Then this popped up.
    Address Settings
    Easy
    Custom
    Easy was highlighted and flashing so I pushed right.
    It said on the screen:
    Enter the connection name.
    Connection Name:
    sbxli
    sbxli was highlighted blicking so I pushed right. It told the Setting List. I don't think I need to worry about that so I pushed right. It told me to "press the "x" button to save settings." So I pushed "x". After that it said:
    Select connection
    [New Connection]
    sbxli
    sbxli was blincing and highlighted so I pushed "x"
    It said connecting to the access point. Please wait........
    Connection Name sbxli
    SSID sbxli
    Exchanging Key information
    Please wait......
    SSID sbxli
    It kept doing that and then it said
    A connection error has occured.
    The connection to the access point timed out.
    SSID sbxli
    HELP PLEASE!!!!!!!!!!!!!!
  • Duck24 Apr 05, 2008
    I don't know anything about anything for my PSP so don't leave out any details for me. Well I want to get on the internet and I have no idea how. I don't know if I have to be some spot or get download anything. So can anyone help me please.
  • Anonymous May 03, 2008
    i try to use wlan to connect but it says error
  • frankie901 Jun 03, 2008
    1. what is my WLAN settings
  • missykay Jun 05, 2008
    i'm having the smae problem but just that mine kept saying connect error 80410410
  • tsenelas Jun 25, 2008
    were the same!!
  • stylez_2pice Jun 25, 2008
    i have the same problem get error 80410a0b
  • luen Jun 26, 2008
    i cannot use my wlan.
  • KAR KAU Sep 09, 2008
  • fable_kid Oct 05, 2008
    it says that a connection has error has occurred. the attempt to obtain the IP address timed out
Ouais
Posted on Sep 19, 2008
    President:
  • 2,961 Answers
The problem is common, you need to set up the psp manually and not let it obtain an ip address automatically. the easiest way is to find either your router ip address or your pc's ip address e.g if your routers ip address is 192.168.2.1, then your pc's allocated address will be 192.168.2.2, so set your psp address to 192.168.2.3. you will also need to set the gateway address, this is your routers ip address(the one you type in your browser to get into the routers settings).e.g 192.168.2.1. the DNS setting will be 255.255.255.0, all other address settings required will be the routers ip address eg 192.168.2.1.
Posted on Aug 02, 2007
SOURCE:
How to turn on bluetooth radio
Which operating system ???...
There are a variety of ways to connect to the Internet or a home/business network using your Hewlett-Packard (HP) desktop computer---via a modem, Ethernet cable and even wirelessly.
A wireless connection works by sending a signal from your modem or router to your HP desktop's built-in wireless radio.
The radio receives and processes the signal so you can access the Internet or a home or business network.
In order for the signal to be received by your HP desktop, you must enable the wireless radio within the computer's configuration.
Click "Start," "Control Panel."
Double-click on the "HP Wireless Assistant" icon.
The HP Wireless Assistant dialog box will open.
Click the "Turn On" button next to the words "Wireless LAN."
Click "Close" to activate the wireless radio.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00045315&product=12455 - DeviceEnabled
Using Bluetooth Devices (Windows XP)
http://h20239.www2.hp.com/techcenter/wireless/wireless_TS.htm
Wireless networking center
Aug 30, 2013 | Packard Bell Computers & Internet
Cannot get my toshiba to join a home LAN workgroup
go to computer, right click and go to properties, and add it to the correct homegroup there. it may be set to something else.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 12, 2012 | Toshiba Computers & Internet
How to internet? realy i dont know
Hi jerichoville,
First off, you have to be in an internet hotspot and your PsP WLAN switch should be turned on ( slide the switch at the left side of the psp upwards). A hotspot means that the area has internet signals that your wireless device can pick-up. If you are at home, make sure that your wireless router is functional.
Now, the steps : -Go to the Main Menu of your PSP. -Go to Settings.
-Scroll down to Network Settings (press the X button)
-Select Infrastructure Mode.
-Select New Connection and assign a name to the connection, then go to the next menu by pushing the Right Directional Key
-Select the Scan, you should now an access point
-Select an access point ( if you see multiple access points, select the strongest network with the Security setting of "None") -Confirm your security setting from the different choices. "DEFAULT" is just about always the correct choice. Push the ">" button again and again until you reach "DEFAULT" -Skip past the Address Settings by clicking the right directional button ">". You should now see a confirmation screen, just click ">". - Press X to save your sttings - Go to TEST CONNECTION and then press X (You should now be connected to the internet at this point.) - Press HOME but this time use the ">" button to move all the way to the right, then "V" to go down to INTERNET BROWSER There you go. Enjoy surfing. Wishing for you to get the best results. All the best to you.
Jul 24, 2011 | Sony PlayStation Portable (PSP) Console
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp help
Did you know you can use your PSP to pick up free wireless internet? Most people don't even realize this but it's pretty straightforward once you know how! Sit back and relax while you learn to get internet on your PSP!
Requirements:
There are a couple of fundamental things you will need before you can start surfing the web with your PSP. The first is some form of wireless internet source. It doesn't matter where it comes from, could be in your home or in your local Starbucks, all that matters is that you are in an area where you can get internet. Psp wireless settings follow the 802.11b wireless networking protocols, which are just about the most common in the world, so most kinds of wireless network connection will be just fine.
Also note that a copy of Wipeout:Pure is necessary to get internet on your PSP.
Sitting comfortably? Ok, prepare to learn how to get internet on PSP!
Step 1- Switch on the PSP and go to the System Menu, and then enter "Network Settings". From there go into "Infrastructure mode", and select a connection to edit. If you already have a home connection set up or something, just select this as the one you are going to edit. Leave the name of the profile as it is, and skip the WLAN settings if they are already set up.
Step2- Go into "Address Settings" click on "Custom" and be sure to leave "IP Address Setting" as Automatic. Believe me; adjusting this will not help you get internet on your PSP!
Step 3- Go into "DNS Setting" and click on manual. This is where we need to type the address of the web gateway we will be using. The most popular one to use for this is the gateway at Endgadget, so input the numbers "208.42.28.174" as the Primary DNS IP, and put zeros for the Secondary DNS IP. (0.0.0.0). If for any reason this gateway is not working you can usually find others with a quick Google search.
Step 4- In the "Proxy Server" options, select "Do Not Use" All you need to do from there is confirm everything, and save it all by pushing X when prompted.
Step 5- Launch Wipeout:Pure as normal, and go into the Downloads menu. When asked to select a connection, choose the one you have just been editing, and you should be presented with the Endgadget web screen. Et voila! How to get internet on PSP!
Provided you have the resource mentioned above, it's pretty easy to get internet on your PSP. Once you have it all set up you'll probably wonder how you got by without it!
Jul 27, 2010 | Sony PlayStation Portable (PSP) Console
How can i take internet in my psp
The PSP is more than a gaming platform. It has WiFi connectivity, and that means that setting up PSP Internet is possible, just like on any computer. The WiFi feature is intended primarily to be used for upgrading software and for downloading games. But you can go several steps further than that, and it isn't difficult to do either.
You need to have access to an Internet connection first and foremost. This can either be at home where you really need a wireless router, or use you can try accessing a public WiFi hotspot like your local Starbucks or wherever.
The most common home set up is an Ethernet cable running from the computer to the DSL or cable modem, which in turn is connected to the telephone line. By installing a wireless router between the computer and the DSL or cable modem, you should be able to connect your PSP to the Internet too.
Of course, setting up PSP Internet isn't just as easy as that! And if you don't have a home Internet connection of any kind, then you'll have to find a WiFi access point that will allow you to connect. This should be reasonably easy in most medium to big cities. But if you live in a small one-horse town way back in the sticks, then maybe, maybe not.
The PSP also needs WiFi access that is the 802.121b wireless networking protocol.
Hmmm... I know what you're thinking. You're thinking, that's it! Way too technical for me! But hold on, it isn't.
This protocol is, thankfully, the world's most popular one. So the chances are excellent that if you find a suitable public WiFi access point, it will be the good old 802.121b wireless networking protocol.
Most people find problems when they come to the more technical bits. Finding the Network Settings, choosing a New Connection, making sure it's Infrastructure Mode - it's all too much for many who try it. Then there's the WLAN Settings to access, a scan to implement for an SSID of any access points nearby, hoping it's not using WEP encryption!
Time to think again...
This isn't rocket science, though some may think it is.
You need, in this order:
1. To have some kind of a proven Internet connection.
2. Select the Infrastructure Mode in Network Settings and start a New Connection.
3. Access the WLAN Settings and initiate a scan to search for suitable access points.
4. Select a suitable access point that is not encrypted.
5. Test the Connection and enjoy!
Sep 10, 2009 | Sony PlayStation Portable (PSP) Console
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
I can't connect even with a full bared-unsecured network option
I'm guessing that you can find your router on the wireless network listing, but when you try to browse the internet you get nothing.
you need to set your IE to Automatically detect your LAN settings
in Internet Explorer choose the Tools menu and select "Internet options" then go to "Connections" tab and press the LAN settings button (near bottom of page) then tick the "Automatically detect settings" box and press OK on both pages.
once this is done close your IE windows and re-open, your IE window should open but take a few seconds to "find it's way out" hopefully then you are done
hope this helps
Mar 23, 2009 | Dell Computers & Internet
Have just bought a computer second hand and have just got internet running with 100% signal but cannot connect because we cannot find local area connection to access files
As dragoness1 says, you don't need a LAN to connect. Right click wireless icon in system tray (bottom right of screen), select "show available Wireless networks". Select one and click connect. If they're not from your own Internet service, they may be protected by a password.
Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
340 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
