Question about Hotpoint BWM12 Front Load Washer
How do i fit the door seal
Hotpoint wf541g
  • 566 Answers
Hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Posted on Mar 09, 2009
It's a hotpoint wf541g washer, I've read the
You can buy bearings but the only way to confirm the exact sizes used is to dismantle the machine and then you will be able to identify the ones used, The main reason they suggest a new drum is sometimes the bearings will not come out or go in easily and can cause the drum to crack which means you would need another drum if this happens.
Mar 04, 2012 | Hotpoint Washing Machines
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do i fit a belt to a hotpoint wf541g washing machine? The belt does not want to stretch around the drum wheeel and motor pulley.
You cannot stretch a belt. There should be a bolt on the motor that you can loosen to allow the motor to pivot, allowing you to easily install the belt.
Apr 09, 2010 | Washing Machines
Please reply
You could Replace the Door Catch/ Hinge. You do not have to replace the Complete Door. It is Relatively easy, if you have any prior experience working on any appliances.
You could check the Part from many Online Vendors like :-
http://www.repairclinc.com
Or you Could buy it from Any Repair Appliance Shop.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 22, 2009 | Washing Machines
All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Oct 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT aquarius WF541G
most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Jun 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
425 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
